R50/53 Hot air
Old Nov 27, 2002 | 11:42 AM
mmmark's Avatar
mmmark
Some days I get an inexplicable breeze of warm air through the small round vents on the dashboard (the ones that don't close) even though I haven't activated the heat. Putting on the auto climate control makes it stop.
Anyone know what I'm talking about?
Old Nov 27, 2002 | 12:42 PM
Arnster's Avatar
Arnster
I was driving the other day with the AC off and windows closed and noticed the same thing.
Old Nov 28, 2002 | 02:55 AM
letsmotor's Avatar
letsmotor
I'd look at the temp setting on the Auto Climate before turning it off. If it is a higher temp, lower it, then turn it off again. The air will be cooler. Another option is to manually direct the air towards your feet then turn off the Auto Climate.
Basically the system has memory of it's last setting before you turned it off. It's just that the fan is not on. Air moving though the air inlets is flowing through the system to give you that hot air you feel.
Old Dec 2, 2002 | 09:37 AM
mmmark's Avatar
mmmark
Thank you. Your explanation should help.
Old Dec 2, 2002 | 10:19 AM
VerucaSalt's Avatar
VerucaSalt
Coordinator :: Mid-Atlantic
I've noticed that I am full of hot air.
Thanks for the explanation, letsmotor!
_________________
<IMG SRC=https://www.northamericanmotoring.com/~sfiveten/L%20Mini%20Sig.jpg>
<a href ="/modules.php?op=modload&name=Messages&file= replypmsg&send=1&uname=l.mini">Sen d
me a PM</a>
Old Dec 2, 2002 | 10:21 AM
2minis's Avatar
2minis
Old Dec 2, 2002 | 11:48 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
I noticed the breeze coming from my vents any time I am moving also. If the problem is the temp, you can adjust the temp as normal, if you don't want the airflow at all, press the button that makes the air re-circulate inside the car instead of picking up outside air.
Sep 3, 2015 01:45 PM
M7Speed
Sep 3, 2015 07:48 AM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 11:15 AM
