R50/53 fix something, another breaks...
Old Sep 23, 2018 | 01:08 PM
mini merle's Avatar
mini merle
So my passenger window on my 2004 Mini Cooper decided to stop rolling down. I ordered a window motor, took the door panel off, discovered the bolts holding the glass in a stripped, watched a video hoping to learn a way around this road block and heard about banging on the motor to see if it might work... and of course it did. I buttoned it back up knowing this would only buy some time until I could get help with removing said stuck bolts.
As I gently pushed the passenger door closed, it didn't close all the way. I tried to open the door, but it had locked. I walked around to the drivers seat and tried the toggle switch for the locks: nothing. *sigh* And now the key will not lock/unlock at all.
I checked and replaced the fuse (although it seemed fine). What next? What would cause the toggle switch to suddenly stop working?
FYI, remote key fob has never worked for me. I've always use the key to unlock the door. And there are only 68,000 miles on the car.
Old Sep 23, 2018 | 02:34 PM
JAB 67's Avatar
JAB 67
General rule of thumb for DIY repairs is "fix 5, break 2."
Old Sep 23, 2018 | 03:35 PM
mini merle's Avatar
mini merle
My husband figured it out after I pulled the door panel for the 3rd time... I had jiggled the door lock stem loose *just a little bit*. Everything works now.
I think she was just mad because I haven't driven her for a while.
Old Sep 24, 2018 | 07:22 AM
MauiWrench's Avatar
MauiWrench
have you tried to program the key to get remote to work ? there is instruction on the web https://www.newtis.info/tisv2/a/en/
Davbret
55
Mar 10, 2019 03:04 AM
Scamp
Tires, Wheels, & Brakes
Mar 17, 2015 02:13 PM
elan
Oct 1, 2012 12:28 PM
skokiedude
Jan 25, 2004 02:51 AM
