R50/53 RPF1 (65mm) center cap adapter for Mini caps
Old Jul 9, 2018 | 10:43 PM
HaltCatchFire's Avatar
HaltCatchFire
Alright, let me acknowledge the folks who say RPF1s should run without caps. I am not one of those people - although I agree those ones you get from Enkei do look pretty odd sticking way out. Nonetheless my hubs are 50% rust by volume and look awful and I really like my old JCW caps.
So I modeled the two wheel openings and printed an adapter ring. This version worked alright, but needs a bit of tweaking - it's a little loose in the wheel and doesn't clear the rear hubs (which appear a millimeter smaller than the fronts, for some reason). Anyhow, once I have the design finalized I'll be posting the files if people are interested in printing their own. Here's a preview:
Old Jul 10, 2018 | 09:00 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
I prefer my wheels naked without center cap to save 0.001 kg. So what I like the most is the yellow Pac-man on the tire. So apt to indicate the correct tire rotation.
Old Jul 10, 2018 | 09:36 AM
JABowders's Avatar
JABowders
Veteran: Army
I would cover the center rings with a little Rust Converter to clean the area up and give it a slight black hue.
But I agree the cool factor is the Pac Man is pretty cool.
Motor On!
Old Jul 10, 2018 | 10:00 AM
pnwR53S's Avatar
pnwR53S
Motor On!
Me like subtle subversion.
I went and checked my new yet to be mounted RE71Rs and each has the yellow dot, though they won't last a few track daze.
Old Jul 11, 2018 | 08:29 AM
Subw00er's Avatar
Subw00er
Share the file! Cool stuff.
Old Sep 7, 2018 | 10:34 AM
HaltCatchFire
Alrighty, the experiment ended in a failure - mostly because the material I used got too soft at the temperature the wheel gets. Ended up losing two caps on the highway. Something with the higher Tg or adding an expansion ring would probably fix that, but I'm done experimenting for now.
Here's the files if anyone wants to try them out. It fits nice and snug when cold and clears the gap to the hubs front and rear.
rpf1_ring.zip
CTScott
Dec 21, 2014 08:34 PM
KyleJ
Tires, Wheels, & Brakes
Jul 24, 2012 02:21 PM
Yucca Patrol
Sep 21, 2006 10:40 PM
MSFIT
Oct 18, 2005 09:41 PM
