R50/53 Momentary Total Electrical Failure
Old Feb 9, 2018 | 08:30 AM
drrigg's Avatar
drrigg
My '04 R53 has been completely reliable for its entire life. Now, suddenly, I have an occasional electrical gremlin that has me concerned. In the last couple of weeks, occasionally, I will be idling at a red light when the entire electrical system goes out just for a second. The engine quits and the lights go out but everything comes back on just as quick as it went out. I don't know where to start looking because it is infrequent, can't be reproduced in the driveway, and always fixes itself. I'm going to check codes to see if anything new pops up (check engine light is always on because cats are temporarily removed). Where should I start looking for problems?
Old Feb 9, 2018 | 11:45 AM
Derek86's Avatar
Derek86
Loose and/or corroded wires is where I would start looking. Fuses, chassis connections and crimped wires where they would be exposed to outside elements is where I'd go first.
Old Feb 9, 2018 | 12:01 PM
JABowders's Avatar
JABowders
Veteran: Army
^^ +1 ^^
Start with the connections; Battery, Chassis Grounds, ECM connector ...
Also have your battery Load tested.
Best of luck tracking down the glitch ...
Motor On!
Old Feb 12, 2018 | 09:30 AM
megaDan's Avatar
megaDan
I have the same problem, but only with the clock/radio. Only when idle dips to 750RPM or so. Engine hasn't cut out...and its winter, so I haven't had the chance to review alternator connections. Battery is new. I'll respond back if I find out what it is.
Old Feb 12, 2018 | 09:38 AM
Derek86's Avatar
Derek86
Check how your regulator is functioning as well.
malibujoey
Oct 14, 2016 06:28 PM
Bugler
Sep 12, 2012 12:45 PM
BearX220
Dec 31, 2006 10:51 PM
kenchan
Jul 28, 2006 06:25 PM
MINIclo
Sep 26, 2002 09:57 AM
