R50/53 Softer riding shock?
Old Dec 25, 2016 | 12:44 PM
  #26
sherman89's Avatar
sherman89
Shocks work both ways and will not necessarily come back to 1/2 way, it depends on the construction and use of the shock. If you go back in posts you will see a video posted by flynbrick showing the strut mount being replaced as well as struts----watch the video and see how much pressure it takes to move the worn strut. That may help you out.
Old Dec 25, 2016 | 12:46 PM
  #27
sherman89's Avatar
sherman89
Do you know how many miles are on the shock? Does it have a white tag on the strut facing the tire side?
Old Dec 25, 2016 | 01:42 PM
  #28
traildog's Avatar
traildog
No idea how many miles.... The fronts have no markings I can find. The rears have tags like you describe.
Old Dec 25, 2016 | 03:59 PM
  #29
sherman89's Avatar
sherman89
The rear shock looks OEM, the strut looks like a OEM replacement. Did you get a look at the video?
Old Dec 25, 2016 | 04:17 PM
  #30
traildog's Avatar
traildog
Yes. It looks like his shocks are a lot easier to compress than mine....
Old Dec 25, 2016 | 05:14 PM
  #31
sherman89's Avatar
sherman89
It's time to make a decision, put the strut back in or replace everything. Do you know a Mini owner that had time working on Minis that can help you or take the car to a shop that can help.
Old Dec 25, 2016 | 05:36 PM
  #32
traildog's Avatar
traildog
Yea, I've decided to change them. The rears are definitely shot and the struts are not smooth when I compress them.
The strut bearings have no damage so, I'll reuse those.
I'm also adding the strut tower plates since they have a small amount of distortion.
Thanks for all the suggestions........
Old Dec 25, 2016 | 05:55 PM
  #33
sherman89's Avatar
sherman89
If the struts are not moving smoothly then it is time to change them out.The Bilstein sport shock is a good shock for DD chores.
Old Dec 25, 2016 | 08:56 PM
  #34
Fly'n Brick's Avatar
Fly'n Brick
Hey, before you add the strut tower defenders make sure any mushrooming is removed. All you need is a block of wood and a heavy or dead blow hammer.
Old Dec 26, 2016 | 03:57 AM
  #35
traildog's Avatar
traildog
Yep, that's on the agenda for today.
Question though. I see in the video that he only uses the plate that goes underneath. I was reading somewhere that the plate should only be used with the support that's mounted on the top.
Or, just use the top support only. Agree? Dissagree?
Old Dec 26, 2016 | 07:49 AM
  #36
Fly'n Brick
The 'on top' plate is the one you want. It just sits down over the tower bolts then tighten down to 25# torque. The video is basically a very helpful advert.
Old Dec 26, 2016 | 06:54 PM
  #37
traildog's Avatar
traildog
BTW, the other strut has the big white stickers on it..........
Old Dec 27, 2016 | 05:01 AM
  #38
sherman89's Avatar
sherman89
It is probably original.
Old Dec 27, 2016 | 09:41 AM
  #39
Andrew Riley's Avatar
Andrew Riley
+1 on the 'Steins as a DD shock. Very affordable and durable. I think mine have about 50k on them, ride is still super smooth even on the crappy SC roads. But when Spring time comes around I'll be stepping up to the Koni Yellows.
Old Dec 27, 2016 | 10:04 AM
  #40
traildog's Avatar
traildog
Yea, no wonder it rides like CRAP.....
Old Dec 27, 2016 | 03:03 PM
  #41
Mini Mania's Avatar
So...... Where's the link to the Bilsteins?
I'd consider them as I've used there products in the past.
Hi Traildog!
Here's a link to the Bilsteins:
http://new.minimania.com/part/NMS309...s-Gen1-R50-r53
Here's for R53 shocks and suspension in general:
http://new.minimania.com/ss/SUSPENSION_NM,SHOCKS_NM
And, here's a whole section on our site just for our R53s
http://new.minimania.com/MINI_Cooper...nd_Accessories
Hope this helps!
