R50/53 I'm Poor Project.
#26
Also My CSF Radiator developed a leak. So CSF sent me another one without asking for the old one back. Good service.
mobile image hosting
I don't think CSF is a crap and cheap company. Leaks in aftermarket aluminum radiators happen all the time, no matter what brand.
The replacement one is holding up well so far.
#29
#30
#32
Originally Posted by ONEBUNCHMIN
Any way to change it? When I get my wheels I'll get them one at a time so I don't spend $1000+ all at once. I wonder if I can do that with coilovers?
#33
If there's a way to change the title than I will. If not than the Mods can delete the thread and I'll start again.
#37
#39
Great methodical work. No matter your thread descriptor your are clearly demonstrating solid building strategy and better yet, you're doing the work yourself. I haven't torn my Mini apart as much as you have and you're just getting started. Keep up the good work!
BTW, you have great choice in color
#40
share pic online
Getting along. Found out my axle was toast. Ordered two new ones from Sneedspeed after failing on cheap Aftermarket ones.
Now I'll clean up the subframe a bit before waiting on the axles to arrive. Yey.
Also. The duel mass Flywheel had around an inch of play in it. So that's why it felt like I had a broken motor mount when all of my mounts were poly/new. Plus the throwout bearing was shot and came apart in my hands.
#41
If someone is put off by the title of your thread, it's their problem and insecurities. Not your problem. Most people are probably just giving you a hard time because that is what the internet is for.
This thread is really good. As I said before, good mods with serious attention to maintenance.
megaDan (07-28-2017)
#44
#45
#46
Good thread, makes me want to work on my R52 again w/ 274K miles. I have seen people repaint the subframe and the control arms when they had those all out, which looks so clean. I just cleaned mine up and put it back together. Should have had if powder coated or repainted it while it was out.
#47
Nobody is really gonna look under there anyways. Plus my timing chain cover is leaking so it'll get dirty again.
#50
