R50/53 I Feel Bad For Asking, But...
Old Sep 18, 2004 | 09:20 PM
HotRodPilot's Avatar
HotRodPilot
Could some of you with 2005's post a picture of what the entire interior looks like at night? Without flash of course
I'm really curious as to what kind of effect the LEDs make and what everything looks like all lit up. The only thing I've seen is the speedometer lit up.
I'd also like to ask if there is a dynamic redline on the tach. It looks as if the redline can change as the car warms up, like in the M5. How long does it take for the engine to revert back to the normal redline, and does it have to be below freezing for it to revert to what could be the 5,500 rpm redline?
Thank you very much:smile:
Old Sep 19, 2004 | 05:56 AM
resmini's Avatar
resmini
Someone else will have to post the pictures but I can tell you there is no dynamic redline on the tach. It is what it is all the time.
Old Sep 19, 2004 | 01:48 PM
HotRodPilot
What are these little dashes that look like they are able to be lit up? I would assume that those lines that are lit up indicating redline, look just like those that aren't lit up when the lights are off...?
Old Sep 19, 2004 | 04:05 PM
JoeDentist's Avatar
JoeDentist
I have the chrono pak, so I'm not sure if my tach is the same, but the "redline lines" do light up red on my tach, even during the day.
Old Sep 19, 2004 | 04:31 PM
Trippy's Avatar
Trippy
The little unlit dashes are so that the same tachometer can be used in the MINI One, the MINI One-D, the MINI Cooper and the MINI Cooper-S. Each has a different maximum RPM.
Each vehicle tells the tachometer what the redline is, and the proper LEDs light.
No one has reported the lights changing during a run, or after breakin or anything like that.
Old Sep 19, 2004 | 04:42 PM
HotRodPilot
Thanks Trippy!
I wonder if MINI/BMW will eventually make it like the tach on an M5 as they update the MINI. I think it would be a very good idea:smile:
Getrieben
Sep 12, 2024 07:03 AM
Getrieben
Aug 17, 2016 06:32 AM
maestro39
Oct 27, 2015 02:38 PM
Inziladun
Sep 3, 2015 10:35 AM
David.R53
Sep 1, 2015 06:49 PM
