R50/53 What is this?
Old Jul 7, 2016 | 02:02 PM
CalicoGal's Avatar
CalicoGal
What is this?
2006 R53.
And should this wire port have a cover on it? Located just below pax side hood latch.
Old Jul 7, 2016 | 03:00 PM
gpwpat's Avatar
gpwpat
Good news and Bad News.
Good News. The Brown wires are Ground wires. So no cover. they are connecting to Ground. Bad news. Looks like corrosion, dirt, junk, got in there. you should clean it re solder or whatever to make sure those wires that need a ground are getting it.
More Bad news. your Hydraulic Motor engine dampener/ motor mount has sprung a leak that is the brown stain. You need to replace it. Bad news. they are not cheap. Good news they are really easy to replace. So it wont take you long or cost you much.
Old Jul 7, 2016 | 03:35 PM
CalicoGal's Avatar
CalicoGal
Thank you so much for the fast reply!! Good info about the ground connector.
Good news!! The the motor mount has already been replaced, that brown crap is the remnant of the old leaks. I guess they didnt do a good clean up like I would have!!
Any idea about what that blue thing is? I can't follow the wires as they disappear under something.
Thanks again!!
Old Jul 7, 2016 | 03:38 PM
David.R53's Avatar
David.R53
Blue thing is the wheel speed sensor connector. The actual sensor is bolted to the knuckle. The zip tiring is common as the connector isn't very tight and can wiggle loose. The pins inside are tiny and easily broken
Old Jul 7, 2016 | 03:45 PM
CalicoGal's Avatar
CalicoGal
AH! I see! Do you know if it is in it's original location? I don't remember seeing it on my previous R53, and it looks oddly mounted...
Thank you for the info!
TheArch0n
Cooper (non S)
11
Sep 20, 2016 06:52 AM
abbey1
39
Jun 13, 2016 04:12 AM
9krpm
Jun 5, 2016 09:04 AM
PhoR53
May 14, 2016 12:13 PM
LTNMUP
Apr 11, 2016 12:34 PM
