R50/53 MINI/BMW tool for parking brake
Old May 19, 2016 | 06:17 PM
ti22fjc's Avatar
ti22fjc
Looks like a job I have to do...pulled the parking brake all the way up and nothing, probably the cables. When I did brakes last year, had to replace right rear rotor...
Anyway, does anyone have this tool that they can borrow out?? Obviously I'll cover shipping and return, more than likely with a Starbucks card or some sort of beverage. In Milwaukee area, so quite a good selection of microbrews...
Old May 19, 2016 | 06:32 PM
David.R53's Avatar
David.R53
The tool for the cable at the handle end or the rear caliper wind-back tool?
I did this without the special tool at the handle end. If you don't need to reuse the special cable holding clip, you can just pry it out with a big screwdriver.
Old May 19, 2016 | 06:42 PM
ti22fjc's Avatar
ti22fjc
Originally Posted by David.R53
The tool for the cable at the handle end or the rear caliper wind-back tool? I did this without the special tool at the handle end. If you don't need to reuse the special cable holding clip, you can just pry it out with a big screwdriver.
I didn't know there was more than one.
Can it be done without either?
Just saw a post with only one special tool.
Haven't had a chance to even look at my Bentley manual.
Old May 19, 2016 | 06:57 PM
David.R53's Avatar
David.R53
If you aren't going to change the pads at the same time, you don't need the wind-back tool.
Check to see if the cables come with the clips. I recall mine did. If so, just pry the old retaining clips off and you don't need the special tool.
Old May 19, 2016 | 07:04 PM
ti22fjc's Avatar
ti22fjc
If you aren't going to change the pads at the same time, you don't need the wind-back tool. Check to see if the cables come with the clips. I recall mine did. If so, just pry the old retaining clips off and you don't need the special tool.
I have a brake caliper tool, didn't link that!! DUH me.
I will check for the clips.
I will have the suspension done in a few weeks, so I may tackle this then.
Old May 20, 2016 | 07:58 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
The Bentley Manual covers the parking brake adjustment on page 340-28. Says to use BMW speciality tool kit 34 6 300 or equivalent. As it's used to turn the pistons while pressing in. The tool part number has a revised part number, which is HERE and is a bit pricey. I'm sure your tool should work just fine. If anyone stumbles upon this and needs other alternative options to the speciality tool, we have a lot HERE.
888.280.7799 | 6am - 5pm PST
JWA
Apr 20, 2016 09:12 AM
speedkills66
Apr 8, 2016 06:25 AM
Mini-Chedrz
Mar 30, 2016 07:40 AM
Sstrickstein
Tires, Wheels, & Brakes
Mar 23, 2016 09:28 AM
rikaro
Mar 23, 2016 08:19 AM
