R50/53 Upper motor mount bolts.
Old 02-01-2016, 09:56 AM
CRC's Avatar
CRC
CRC is offline
I purchased a new OEM upper motor mount for my R50 from a fellow member, on marketplace. Unfortunately, it came without the bolts. Could one of our vendors tell me which ones I need?
Old 02-01-2016, 10:27 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
Are you talking about the upper passenger side engine mount? The torx bolt, #5 below is HERE. #4 hex bolt is HERE.
888.280.7799 | 6am - 5pm PST
Old 02-01-2016, 10:16 PM
CRC's Avatar
CRC
CRC is offline
Yep, those are the ones. Thank you.
Old 02-02-2016, 04:54 AM
Shawnnn's Avatar
Shawnnn
Shawnnn is offline
Did you lose your old bolts? You don't need to replace them if you didn't.
Old 02-02-2016, 07:25 AM
CRC's Avatar
CRC
CRC is offline
Still have the old bolts, just get kind of obsessive about replacing bolts when I fit new parts.
Old 02-02-2016, 07:35 AM
RB-MINI's Avatar
RB-MINI
RB-MINI is offline
I think bolt 5 is the only bolt that is a one time use bolt and should be replaced if you were to use your old ones.
Old 02-02-2016, 10:05 AM
nkfry's Avatar
nkfry
nkfry is offline
Bolt 5 is the only single use bolt on the engine mount, everything else will be fine. Torque them to spec and you'll be okay.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old 02-02-2016, 10:21 AM
CRC's Avatar
CRC
CRC is offline
Thanks all for the good info. Bolt 5 it is.
Old 02-02-2016, 10:22 AM
Shawnnn's Avatar
Shawnnn
Shawnnn is offline
While I'll admit I should be a little more like CRC, I will take my chances on those bolts easily lasting the life of my Mini.
Now when I did my head gasket I definitely bought new bolts.
Peace of mind is worth something though. I have a friend that checks the pressure in his tires religiously , despite the fact he has a sensor for it.
Old 02-03-2016, 11:09 AM
nkfry's Avatar
nkfry
nkfry is offline
Headbolts are a single use TTY bolt, I am glad you didn't try to reuse them. Big jobs like that aren't fun a second time round.
The TPMS system is a fickle mistress, I've had cars come in with 36 PSI in 3 tires and almost 60 PSI in the last and no light on the dash, just a strange pull to the left.
Phone:586-792-6464
Old 02-03-2016, 11:20 AM
Shawnnn's Avatar
Shawnnn
Shawnnn is offline
Like I said, I should be a little more **** about some things. But my engine falling out from reusing motor mounts wont keep me awake at night lol
Not to derail the thread, but thats pretty scary that someone filled their tire to 60 psi then wondered why it was pulling. Good thing those people check in with you.
dw3
08-01-2016 04:17 PM
JCW_Coupe
02-17-2016 02:24 PM
rrsuby25rs
02-08-2016 10:05 AM
goldchild
01-31-2016 02:29 PM
98oilhead
01-31-2016 01:10 PM
Quick Reply: R50/53 Upper motor mount bolts.
