R50/53 Fuel smell in car
Old Dec 29, 2015 | 11:48 PM
mhopper49's Avatar
mhopper49
Fuel smell in car
Have an 05s 150k miles. Here in the past few days I have had a fuel smell inside the car. I can't smell anything outside. No leaks from what I can see. I am guessing might have something to do with the fuel filter, since you change it under the passenger seat
Old Dec 30, 2015 | 04:51 AM
whaap's Avatar
whaap
I had that happen once on a CRX I owned. The problem was I hadn't seated the gas cap properly. Check to make sure it's 'clicked'.
Old Dec 30, 2015 | 07:26 AM
Check gas cap, did you overflow the gas tank or top it off too much and flooded the charcoal canister in the back near the fuel tank.
Did you change the fuel filter recently ?
Did someone spill gas at the station and you accidentally walked over it and then got a little on the floor mats, does not take much.
Old Dec 30, 2015 | 09:16 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Check the gasket for the fuel pump under the rear seat. Also, definitely make sure you don't have a fuel leak somewhere. The vent valve has been known to give some trouble and cause the cabin of the vehicle to smell like fuel. Some info HERE.
888.280.7799 | 6am - 5pm PST
bighaus90
Jan 7, 2017 09:28 AM
Skummdogg
May 17, 2016 02:23 AM
lockup
Dec 29, 2015 08:00 PM
45rake
Dec 28, 2015 11:49 AM
Dec 24, 2015 10:32 AM
