R50/53 When is it time for a new/rebuilt supercharger?
Old Dec 17, 2015 | 08:49 AM
  #26
dw1's Avatar
dw1
@sevin: to kill the unknown on gearing, do an RPM v speed check in 1st or 2nd gear on yours and then go do the same thing on the car in question. I would also consider adding a boost gauge to yours to verify boost level and also check the rubber hoses on yours for any leaks to verify your setup. Compression & leak down test may also tell you something.
Old Dec 17, 2015 | 08:57 AM
  #27
sevin's Avatar
sevin
I don't think it'd be a good idea to go back at this point since I've been twice and have no plans to purchase the car. I'll definitely check around my hoses and see what I can find, I know that my intake boot has a crack in it. I may be able to do some compression/leakdown tests at school at school sometime.
Old Dec 21, 2015 | 10:57 AM
  #28
Kahnfucious's Avatar
Kahnfucious
If your intake boot is cracked - I would also take a look at your intercooler couplers ... It's actually not that uncommon for them to fail and leak and cause a loss in boost
Old Dec 21, 2015 | 11:21 AM
  #29
sevin's Avatar
sevin
I think my couplers look good. I will take another look.
Old Dec 21, 2015 | 12:10 PM
  #30
IQRaceworks's Avatar
IQRaceworks
Originally Posted by Vkng
I'm over 140k miles on my original charger with a 15% pulley, and it still gives normal peak boost.
I'm of the opinion that you run it til it fails, then replace.
You could have a bad bypass valve that's keeping your boost low.
I'm at this point also.....140,000 miles.....no issues. I think drive it until it starts making noise is the best way to tell when it needs replaced.
Old Dec 21, 2015 | 12:54 PM
  #31
sevin's Avatar
sevin
Just took the intercooler and couplers off. All looks good. I did notice a pool of oil inside the smaller coupler, the one on the right side (inlet or outlet?). The other was slick with oil but no pool.
Old Dec 21, 2015 | 02:17 PM
  #32
sevin's Avatar
sevin
What is this connector here?
I just drove ~25 minutes with it disconnected . The CEL came on about 20 minutes in. I thought it was a boost leak since the car felt down on power but when I opened the hood up I realized I had left this connector disconnected. The CEL hasn't gone off yet, but I've only been letting the car idle for a couple minutes in my driveway, so I'm just hoping it hasn't cycled yet.
Old Dec 22, 2015 | 07:56 AM
  #33
sevin's Avatar
sevin
Anybody know? I'm curious.
Old Dec 22, 2015 | 08:25 AM
  #34
nkfry's Avatar
nkfry
That is your knock sensor, you will need to clear the codes and cycle the ignition and the light should go out assuming you don't have more going on.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Dec 22, 2015 | 08:28 AM
  #35
sevin's Avatar
sevin
Oh, I guess that doesn't explain why it felt down on power... isn't there a way to clear the codes using the trip reset button? I don't have something else I can use to clear codes.
Old Dec 22, 2015 | 08:42 AM
  #36
nkfry's Avatar
nkfry
Go to Autozone or the local parts store that does "free computer scans" and have them clear the codes.
The knock sensor is only there to monitor for pre detonation, the car probably went to limp mode because it was unable to read the sensor and adjust timing accordingly.
Phone:586-792-6464
Old Dec 23, 2015 | 11:04 AM
  #37
Kahnfucious
As nikfry stated - it definitely does. If the car stops getting signals from critical sensors it's going to make adjustments to protect the engine. The knock sensor is critical and since it couldn't tell if there was an issue it pulled timing and put you in limp mode
Old Dec 23, 2015 | 11:20 AM
  #38
sevin's Avatar
sevin
That makes sense. Thanks for the clarification.
1chaos52
May 24, 2020 03:07 PM
Jesse Mattingly
Oct 10, 2015 05:06 AM
AoxoMoxoA
Oct 7, 2015 11:25 AM
mini_mike237
Cooper (non S)
Oct 7, 2015 08:06 AM
nshannon29
Oct 7, 2015 05:57 AM
