R50/53 FYI: CAN bus issues causing electrical problems 2006 R53
Old Oct 19, 2015 | 10:06 AM
jrodusmaximus's Avatar
jrodusmaximus
Tach/Auxillary Cluster was faulty.. intermittently disrupting CAN communication for all modules connected.
Symptoms:
First the tach/auxillary cluster on the steering column would appear to turn off while driving, or when sitting parked.. But the backlighting would still work. Didn't have the time to fix it so I let it do it's thing while I ignored it. Then a few weeks later I was driving and started having a whole new batch of symptoms --> ABS light, Check Eng Light, Tire Pressure Light, Eng Temp gauge fluctuating to max, A/C compressor disengage, Cruise disengage, Tach fluctuation, Speedometer needle fluctuation.
Scanned faults:
DME
P1613- Serial Communication with ASC
P1607- CAN status
ABS/ASC/DSC
5E14- CAN: Connection with Engine ECU Failed
5E16- CAN Instrumentation
5E1E- Steering Angle Sensor CAN
5E18- CAN: Data Error from Engine ECU
5E11- CAN: Control Module
INSTRUMENT PANEL (KOMBI)
60- CAN Bus, Bus Offline
61- CAN: No Signal
67- CAN: Timeout KOMBI
62- CAN: ABS/ASC Signal
While car was acting up, left the scanner connected and disconnected the tach/auxillary cluster. All the current CAN codes left, and the car functioned like it should. Reconnect the tach, and the CAN issues come right back. I'm driving tach-less right now with no issues.
Note: Other modules connected to CAN can cause similar problems..
Update: 10/28/19. Used replacement tach was installed shortly after the original post and is still working nicely.
Last edited by jrodusmaximus; Oct 28, 2019 at 08:06 PM. Reason: To many "me"'s and "I"'s... I was pretty proud of my find apparently...
Old May 4, 2019 | 10:26 AM
Jim Willittes's Avatar
Jim Willittes
Fix??
Did you ever get a new tach or just go tachless??
Old May 6, 2019 | 01:36 PM
jrodusmaximus
Replaced with a used one and it's been good ever since. So.. approximately 4 yrs ago now
Old Oct 22, 2019 | 07:19 AM
lotter1's Avatar
lotter1
Good morning,
Stumbled on your thread, I have the same issues. Was the tach just a swap and go? Any programming needed?
Old Oct 28, 2019 | 07:54 PM
jrodusmaximus
Originally Posted by lotter1
Good morning,
Yes sir, just a swap and go thankfully
Old Oct 29, 2019 | 09:13 AM
lotter1's Avatar
lotter1
Swapped
Thanks! I did swap it and all the codes were gone except the steering angle one. I reset the sensor and so far so good!
Thanks again for the info, who would have thought the tach was the culprit!
MrMicL
Dec 22, 2023 04:39 PM
j-gregs
Jul 12, 2020 06:02 AM
Tyler767
25
Feb 28, 2019 09:12 PM
MiniBlueVancouver
Jun 4, 2015 06:45 AM
dwgates
Feb 3, 2007 08:10 PM
