R50/53 Clutch replacement
Old Aug 28, 2015 | 06:18 PM
robertcoyle's Avatar
robertcoyle
Recently changed the clutch and thrust bearing on my 03 Cooper non S, it's working great now except for slight rattle when the clutch is released, I was very careful when when putting it back together and followed a YouTube vid by Minimod and also followed the instructions of the BMW TiS manual. Any ideas on what that could be? The reason why I ask is I have the car booked in with Mini for oil change. Any input with be very great full.
Old Aug 29, 2015 | 06:16 AM
w4r3z's Avatar
w4r3z
Which clutch did you replaced it with ?
Old Aug 29, 2015 | 06:33 AM
bjcarter2's Avatar
bjcarter2
Is it a rattle or is it chattering? If the clutch was not broken in or is hot, it can chatter a bit. Chattering is possible too if you put a heavy-duty clutch in such as one with race style construction - a six-puck.
Old Aug 29, 2015 | 08:10 AM
robertcoyle
It was a Sachs clutch. So how long does it take to brake in a new clutch, I've been drinking it carefull.
Old Aug 29, 2015 | 01:06 PM
WingZombie's Avatar
WingZombie
Did you replace the tube in the trans the throw out bearing rides on?
Old Aug 29, 2015 | 02:40 PM
robertcoyle
I did, yes.
Old Aug 29, 2015 | 03:19 PM
Shawnnn's Avatar
Shawnnn
Break in is about 500 miles of easy driving
Could be the throw out bearing or maybe a noisy clutch.
I assume you bought a new pressure plate, did you do anything with the flywheel?
Old Aug 29, 2015 | 03:53 PM
robertcoyle
I installed a new pressure plate, clutch, bearing and guide rod. The flywheel was in really good condition. I did figure that it would need to be run in, just wasn't sure for how long. Does sound less noisy the more I drive it.
Finhead
105
Aug 14, 2023 07:51 AM
eliseo1981
Jan 28, 2021 02:45 PM
PrimePower
Aug 16, 2015 06:29 PM
Powershift
Aug 16, 2015 05:14 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
