R50/53 Meth injection with no change to the tune.....any gains?
Old Jun 30, 2015 | 07:31 PM
IQRaceworks's Avatar
IQRaceworks
I've done some research on meth injection, and it sounds like you can get a pretty decent setup for under $400. Most of the guys I see running the meth injection also have custom tunes setup to take advantage of the methanol.....more timing! I know that running more timing, and a cooler intake charge will give you more power.
But.....do any of you guys have a meth injection setup on your R53 and run the same tune you had BEFORE you added the meth injection? I'm assuming that this way, the only gains you actually see from the meth injection are cooler intake temps/ What kind of power gains does that make?
I guess the simple version of my question is this......without a custom tune designed to take advantage of the meth injection......is a meth injection system worth the money?
Old Jul 1, 2015 | 06:02 AM
Saltysalt's Avatar
Saltysalt
it would essentially act like an intercooler, a really good one. since the intake temps would never see the area where timing would be pulled, it allows you to keep your power. you may get a bit more power, although youll be running richer, but youll have a higher octane boom.
if you tune for it, that's when you make the stupid power.
especially on the hotter days, that is when youll see this make a difference
Old Jul 1, 2015 | 03:48 PM
wellzy's Avatar
wellzy
You can run a meth kit on the same tune, just a smaller jet, It will keep the air intake temps down.
I do that with my car.
Running a Aquamist HFS2 its been perfect.
khumpert
Nov 30, 2015 11:48 AM
Mib4840
Oct 13, 2015 10:10 AM
sprp85
Aug 22, 2015 06:16 AM
Aug 21, 2015 11:25 AM
FLYM1N1
Aug 16, 2015 01:17 PM
