R50/53 Did I waste my money? - Bavtechnic scanner
Old Jun 5, 2015 | 06:54 PM
fancy sauce's Avatar
fancy sauce
I bought the scanner as a means to figure out whether my low speed fan issue was caused by my ac compressor not functioning, or if my ac compressor was not coming on due to my low speed fan not coming on.
when using the scanner, it does not allow me to activate the ac system or the fan to determine if either are functioning. am i doing something wrong, or was this a poorly spent $180?
Old Jun 5, 2015 | 08:31 PM
cdemarco4's Avatar
cdemarco4
I'm not a coding expert with Minis but I believe this was a wast of 180 bucks. I'm sorry to brake the news to you. All the programs that you could possibly need are available free online to download onto your laptop. Then either purchase a cable that goes from computer to OBDII (forgot the name) or if the laptop is Bluetooth enabled just get a Bluetooth OBDII scanner tool for 15 bucks on amazon. That's what I do. You can use this for any info sent over OBDII. I mostly use it to run torque and AP Soft. Motor on and good luck. Search the forums for more specific info.
Old Oct 13, 2015 | 07:54 PM
Jim Ferrell's Avatar
Jim Ferrell
which software works with the pc to OBDII cable?
Old Oct 13, 2015 | 09:40 PM
Eric_Rowland's Avatar
Eric_Rowland
Per the Bentley manual, and confirmed by my ScanGauge, the fan operates at low speed at 221F, and turns off at 214F. The fan switches to high speed at 234F and remains on high until the coolant temps drops by 7F. Supposedly it also turns on when the AC is on and the AC system pressure reaches 8 bar (114psi)
You don't need a scanner to test the low speed fan. Just get the coolant temp. In my case (and reported by others) the low speed fan went out, and that allowed the AC to overheat and die. At least in my case both my low speed fan and AC both died.
RobbyD
Jan 29, 2019 01:22 PM
navybsn
Oct 5, 2018 04:42 PM
vetsvette
Oct 11, 2015 06:05 PM
OldElvis
Oct 5, 2015 07:31 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
