R50/53 R50 low RPM struggle off line 'yo yos' 81k miles
Old May 28, 2015 | 07:56 AM
dscott90000's Avatar
dscott90000
Before 3500 rpms my mini really doesnt get going to well. I have heard people say Yo Yos , sputtering etc.
What needs to be done here? I will pull a plug or 2 and check those out, see what the P.O put in. Fuel filter?, Sea foam? Coil packs?
Old May 28, 2015 | 08:34 PM
Kahnfucious's Avatar
Kahnfucious
Originally Posted by dscott90000
Before 3500 rpms my mini really doesnt get going to well. I have heard people say Yo Yos , sputtering etc. What needs to be done here? I will pull a plug or 2 and check those out, see what the P.O put in. Fuel filter?, Sea foam? Coil packs?
Yo yo is a term used for supercharged minis which have a bypass valve and I don't think applies to justa coopers. We need a lot more details before we can diagnose - mileage, mods, last tuneup etc..
Old May 29, 2015 | 12:15 AM
spingq's Avatar
spingq
My previous R50, which had its trans fail at 75,000 miles, became increasingly more difficult to get going at low RPMs when i got to around 120,000. It would stutter and shake violently if I put too much on the gas from a stop (and I'm talking like anything more than an extremely feather-weight touch). I had hoped new plugs and the usual tune-ups would help this, but nothing did. My assumption was that it was a sign the trans was on its way out again. NOTE though, the car did not demonstrate these stuttering symptoms prior to the original trans failure at 75k - my only warning symptom before that was the car's hesitance in upshifting at around 60mph. It would stick and I'd be cruising at an average of about 4500 RPM if I remember correctly, instead of hovering much lower like it should (I've been told MINIs should hover in the 2500 RPMs pretty much through all its "gears"). After failure though, the trans was rebuilt, not replaced. And from what I've heard, a rebuilt R50 trans is a crapshoot in terms of reliability.
Old May 29, 2015 | 06:42 AM
ZippyNH's Avatar
ZippyNH
+1
To have a similar issue on a r50 is kinda odd...
Try starting with the ac off...maybe you are just bogging down.
Old May 30, 2015 | 06:51 AM
dscott90000
starts great , just has a weak throttle response .... maybe an exhaust and headers will do....
Old May 30, 2015 | 10:12 AM
Kahnfucious
Don't do it - modifying an r50 is an excercise in futility. Gen 1 minis even supercharged ones aren't design to be great at straight line acceleration. Corners is where it's at. Before someone posts me a link to the worlds fastest mini on the drag strip - just remind yourself that's a race shop and the car is far from stock AND bolting things on won't get you there.
Old May 30, 2015 | 04:35 PM
pilotguy1050's Avatar
pilotguy1050
New plugs - amazing change.
I had the same problem last week. Two issues and one action fixed both for me:
(1) replaced all four spark plugs. The platinum 4-pronged ones went right in. Car had them already, one had the electrode almost gone.
(2) while installing new plugs, found one plug wire touching the coil housing, rubbing into the wire ... May have been a partial short on acceleration... Rearranged the wires.
After that, I had a new-running car.
iggi
18
Feb 9, 2026 01:00 AM
Svejk
Feb 24, 2019 12:18 PM
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:59 PM
Aug 11, 2015 12:58 PM
