R50/53 Rough engine noise R53 mini - video provided
Old Apr 29, 2015 | 06:25 AM
Bradlee's Avatar
Bradlee
Oil level was just checked and is fine. When turning the car off, the engine seems to grind to a halt... the last few cycles seem pretty distinct. This issue does not resolve itself after the car warms up.
Any thoughts?
Old Apr 29, 2015 | 08:05 AM
Kahnfucious's Avatar
Kahnfucious
Two possibilities:
Timing chain tensioner (cheap and fast fix)
Belt tensioner slapping around (not as cheap but still cheap and more involved replacement)
Old Apr 29, 2015 | 09:17 AM
Bradlee's Avatar
Bradlee
Great, thanks for the info! I'll check those issues out
Old Apr 29, 2015 | 09:21 AM
Swimbaxter's Avatar
Swimbaxter
Originally Posted by Kahnfucious
Two possibilities:
+1
Mine did this last week. It was the Timing Chain Tensioner. Park it until you fix it as you can damage the tensioners themselves and put plastic and metal bits into your oil pan and clog the oil pick up. This would be a much more expensive fix. $50 for a a new TCT and a 19mm wrench and a half hour watching you tube videos and you can be back in action.
Good luck!
iggi
18
Feb 9, 2026 01:00 AM
Getrieben
Sep 12, 2024 07:03 AM
maestro39
Oct 27, 2015 02:38 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
