R50/53 Grinding rotational noise when driving on right side :(
Old Nov 12, 2014 | 01:45 PM
tragedybysyntax's Avatar
tragedybysyntax
So i've been getting this sound mildly a few weeks ago... and as of last night it got a lot worse. I had taken off the wheel a few days ago to see if the sound was coming from grinding on the rotor dust shield, or the pads were wearing down at an odd angle. Everything was fine... so today since I had some light i figured i would take the wheel off again and look around. The only thing I can see is maybe this? Should there be a gap here at the end of the drive shaft? :/
Old Nov 13, 2014 | 06:13 AM
dcantwell's Avatar
dcantwell
Sounds like a wheel bearing to me?
I never had grinding noises with the axles. Recently replaced them for other reasons.
Old Nov 13, 2014 | 06:33 AM
tragedybysyntax
well now it's clicking a bunch... sounds really bad. I ordered the cv axle, but I'm taking it up to a mechanic tonight to make sure that's what he thinks it is
Old Nov 13, 2014 | 07:50 AM
dcantwell's Avatar
dcantwell
Amazon.com: Cardone 60-9280 Remanufactured CV Axle: Automotive Amazon.com: Cardone 60-9280 Remanufactured CV Axle: Automotive
That's the axle I just used to replace my driver side on Monday.
I've gone through a bunch of axles and this one seems to run great so far. Be careful where you get them from...
My mechanic had to shave a few thousandths of an inch off the driver side axle because it wouldn't fit right. Had it fall out on me.
Old Nov 13, 2014 | 08:48 AM
tragedybysyntax
Hey that's the exact one I ordered! Apparently the passenger side is easier because there isnt any clip to remove at the transmission. Looks like it comes in on wednesday...
Old Nov 13, 2014 | 10:43 AM
dcantwell's Avatar
dcantwell
The Passenger is actually a little harder I think. There's a bracket you need to kinda be careful with. Unless it comes with it (I didn't do the work so I'm not sure).
If you do it yourself, make sure you have the axle in fully. The mechanic mentioned a click. I'm not sure. Just double check for leaks and such. Don't let it fall out on you like I did... lol
Here's a POV video of how to do it:
This guy has great videos. Even cool to watch.
Melvinyip
Apr 17, 2020 09:28 AM
maestro39
Oct 27, 2015 02:38 PM
theblackfalcon
Oct 11, 2015 09:49 AM
cm.d
Aug 19, 2015 08:51 AM
