R50/53 Losing oil on an 2004 Cooper S
Old 09-30-2014, 12:35 PM
ijourneaux's Avatar
ijourneaux
ijourneaux is offline
I changed the oil 5-6 weeks ago and today, I noticed the level was way down about 1 qt. There is oil covering the front of the oil pan but I don't have any dripping onto the garage floor. From other threads, it seems there is a gasket on the front of the engine that tends to leak?
Since it seems to be a fairly involved task to get in there, is there anything else I should do while I have the front opened up?
Is this oil consumption normal?
Old 09-30-2014, 01:32 PM
AudioNToxication's Avatar
AudioNToxication
AudioNToxication is offline
How many miles on car and how many miles since you did the oil?
The crank position sensor gasket leaks. Things you can do while you are in there, service the blower, new belt, replace water pump, service cooling system in general.
Old 09-30-2014, 03:57 PM
ijourneaux's Avatar
ijourneaux
The Mini has 85000mi on it. I have driven possible 2-3k miles since the oil change. I was <less than a quart low.
Thanks for the tips on what else to do when I have the front off.
Ian
Old 09-30-2014, 04:57 PM
AudioNToxication
1Qt. in 3K isn't too bad. I was doing about 1Qt. in 1k miles for a little bit.
You should probably adopt the 3-5k oil change interval. Then you don't have to worry too much about it.
Old 09-30-2014, 05:40 PM
ZippyNH's Avatar
ZippyNH
ZippyNH is offline
The crank position sensor gasket can be done in under an hour....
You jack the motor up...and swap it...
Or do service mode, bumpers off....and reach in and do it...pick your method.
I would clean the area.... And monitor...
Old 09-30-2014, 06:07 PM
AudioNToxication
Zippy is right. Clean and monitor. Could possibly be oil pan gasket. Do you park on a hill?
07-16-2020 12:54 PM
PrimePower
08-11-2015 12:51 PM
wind715
08-11-2015 07:56 AM
oldsbear
Eastern Iowa MINIs
08-09-2015 04:02 PM
M7Speed
08-06-2015 01:48 PM
Quick Reply: R50/53 Losing oil on an 2004 Cooper S
