R50/53 Help me with window regulator
Old Jul 16, 2014 | 08:01 PM
Gigantor's Avatar
Gigantor
I have a new regulator, but I don't remember how the motor mounts. Is this correct?
Old Jul 16, 2014 | 08:02 PM
Gigantor's Avatar
Gigantor
Old Jul 16, 2014 | 08:04 PM
Gigantor's Avatar
Gigantor
I can only get two screws in to mount it, how do you get the other two in?
Old Jul 17, 2014 | 06:53 PM
Gigantor's Avatar
Gigantor
Anybody?
Old Jul 18, 2014 | 07:13 AM
What year and model do you have in 6/2005 there was a change in the part number, want to make sure you are not a pre 6.2005 into post 6/2005.
Here is the diagram to help:
Window Electric Motor - Front Left -6/2005
http://www.ecstuning.com/Search/SiteSearch/67626955875/
Window Electric Motor - Front Right ( passenger ) Part # 67626955876 -6/2005
http://www.ecstuning.com/Search/SiteSearch/67626955876/
And the window regulators.
Window Regulator - Front Left ( driver ) Part # 51337039451 -6/2005
http://www.ecstuning.com/Search/SiteSearch/51337039451/
Window Regulator - Front Right ( passenger side ) Part # 51337039452 -6/2005
http://www.ecstuning.com/Search/SiteSearch/51337039452/
For 6/2005+ There was an additional bracket for the connection between the motor and the regulator.
Window Electric Motor - Front Left part # 67626954275 6/2005+
http://www.ecstuning.com/Search/SiteSearch/67626954275/
Adapter Plate - Left Part # 51337197471 6/2005+
http://www.ecstuning.com/Search/SiteSearch/51337197471/
Window Electric Motor - Front Right 6/2005+
http://www.ecstuning.com/Search/SiteSearch/67626954276/
Adapter Plate - Right part 51337197472 6/2005+
http://www.ecstuning.com/Search/SiteSearch/51337197472/
Regulators: 6/2005+
Window Regulator - Front Left 51337162163 6/2005+
http://www.ecstuning.com/Search/SiteSearch/51337162163/
Window Regulator - Front Right 51337162164 6/2005+
http://www.ecstuning.com/Search/SiteSearch/51337162164/
Thanks and check the pics to make sure your match up.
Old Jul 18, 2014 | 10:33 AM
Gigantor's Avatar
Gigantor
Thanks. I have a 2004.
Old Jul 18, 2014 | 10:49 AM
You are welcome, check the regulator and the motor, looks like the correct one for pre 6.2005 and orientation. ( based off your 2004 ).
You have the 11 digit part number above for reference. The motor could not be set in and a hair off. The nylon screw hole mount on the regulate side might be off a bit. Looks correct from the pic. Just double check the regular part number and inspect the connection.
If you need that gear window wrench we have it here. For the gear socket you tighten down.
Window Regulator Nut Wrench 83300494251
http://www.ecstuning.com/Search/SiteSearch/83_30_0_494_251/ES199501/
Thanks and good luck.
USNAE2
16
Jun 17, 2022 07:17 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
rt808
Sep 25, 2015 01:59 PM
