R50/53 Finally, Gen1 Power Steering Delete Kit Available Soon!!!!
Old Aug 18, 2014 | 05:45 PM
  #126
minsanity's Avatar
minsanity
alliance of motoring.....in reverse
Old Aug 22, 2014 | 08:32 AM
  #127
jskeith111's Avatar
jskeith111
From: NW Indiana (45 min south of Downtown Chicago)
I can't figure this out for the life of me!
I'm trying to pull the fuse for the PSP. The fan and pump are all on f41 correct? (05 MCS)
The pump still runs even with the fuse pulled.
Am I doing something wrong?
Old Aug 22, 2014 | 08:44 AM
  #128
Kahnfucious's Avatar
Kahnfucious
try fuse 39 -- you just disabled the fan i think which I think is tied to the radiator cooling fan so you might want to put fuse 41 back.
Old Aug 22, 2014 | 08:47 AM
  #129
jskeith111's Avatar
jskeith111
41 is back in. 39 did the trick. I can leave this fuse out correct? It won't affect anything else by having it removed?
When I started my car and didn't hear the groaning, loud, annoying pump... I sat there for a second and did exactly this, almost with tears in my eyes.
I don't care if the wheel is difficult to turn. The sound being gone is well worth it to me. Especially since my pump was nearly dead.
Old Aug 22, 2014 | 09:57 AM
  #130
minsanity's Avatar
minsanity
The delete kit will make steering easier than having that dead pump in.
Edited: Fuse 39 is for both the alternator & the PS Pump.
Old Aug 22, 2014 | 10:05 AM
  #131
jskeith111's Avatar
jskeith111
Will definitely purchase. Someone on here mentioned on a scale of 1 (dead pump) to 10 (fully working pump) this delete is about a 3-4 in terms of how tough the wheel turns?
Is this accurate?
Old Aug 22, 2014 | 03:00 PM
  #132
minsanity's Avatar
minsanity
That same guy gave an updated review I shared on post 124. After 3weeks, he's loving it & would never go back to having a pump.
Old Aug 22, 2014 | 03:44 PM
  #133
jskeith111's Avatar
jskeith111
My battery light is now on. Is this something you guys have seen as well by removing the fuse?
Old Aug 22, 2014 | 04:16 PM
  #134
minsanity's Avatar
minsanity
Mine did twice. 1st when my alternator died, 2nd when my crank pulley decided to die. Rebuilt the former & replaced the latter w/ ATI.
Edited: Fuse 39 is the cause. Don't remove that to disable PS Pump as the alternator is hooked w/ it. Check the fuse/relay/grounding directory on post136 below.
Old Aug 22, 2014 | 06:15 PM
  #135
jskeith111's Avatar
jskeith111
I put 39 back in and the light turned off
Old Aug 22, 2014 | 06:58 PM
  #136
minsanity's Avatar
minsanity
Gen 1 Fuse/Relay Directory:
http://www.sunshineminis.org/forums/...?f=113&t=19371
You took out the wrong 5A fuse from inside the car.
F39 5A Alternator/Electric Steering control unit/hydraulic pump
Go to the engine bay fuse box:
FL4 100A Electric Steering control unit/Hydraulic pump
Old Aug 22, 2014 | 07:40 PM
  #137
Da_Ghost's Avatar
Da_Ghost
The FL4 100 amp fuse for the power steering is UNDER the fuse box (for my 2005 at least). You need to disconnect the battery, remove the positive cable on the fuse box and the two bolts holding the box, then flip it over and remove the cover. There's 2 or 3 fuses under there, just make sure it's the correct one you're taking out and they are held by torx screws.
Old Aug 22, 2014 | 08:12 PM
  #138
Odin2free's Avatar
Odin2free
This is epic.
Should put the Fuse Info on the topic #1 for people to have quick reference to it.
Just ordered.
Will await in mail. Install and give a feedback on it.
Old Aug 22, 2014 | 08:51 PM
  #139
minsanity's Avatar
minsanity
Thanks for the first hand info, Ghost!
Old Aug 22, 2014 | 09:10 PM
  #140
minsanity's Avatar
minsanity
Originally Posted by Odin2free
This is epic.
Inserted Da_Ghost's instructions on removing FL4 100A fuse in posts 1 & 106.
Old Aug 25, 2014 | 03:43 PM
  #141
RDY4TKF's Avatar
RDY4TKF
Sorry for taking so long to post my review. My power steering pump was making the most annoying, embarrassing whine so I disconnected it around May. I drove around like this trying to decide what I was going to do. I saw the posting about Condor making the ps delete so I thought I would wait and give it a shot. It is definitely an improvement over just disconnecting the pump. It is not night and day but enough to where I am happy to have installed it. Obviously I miss the quickness of my steering when the pump was fully operational. The power steering pump was kind of heavy so at least it's not dead weight now that it is off of the car. In the future I will probably buy a new pump but for now I'm happy. Only super tight spots is where the steering is a struggle.
Old Aug 25, 2014 | 03:52 PM
  #142
minsanity's Avatar
minsanity
Thanks for the honest review, RDY4TKF. People have been waiting what those who've installed the kit have to say.
Old Aug 28, 2014 | 11:06 AM
  #143
MiniManTim's Avatar
MiniManTim
Originally Posted by minsanity
Condor Power steering Delete Install Procedures
1. Remove your power steering system. This includes the pump, FL4 100A PS Pump fuse in the engine bay fuse box, lines, and reservoir.
Da_Ghost shared this:
The FL4 100 amp fuse for the power steering is UNDER the fuse box. You need to disconnect the battery, remove the positive cable on the fuse box and the two bolts holding the box, then flip it over and remove the cover. There's 2 or 3 fuses under there, just make sure it's the correct one you're taking out and they are held by torx screws.
2. Turn your rack full lock from one side to the other side 3-4 times. This removes unnecessary fluid.
3. Slide 1 washer onto the smaller banjo bolt. Slide the delete onto the smaller banjo bolt. Now slide 1 washer onto the same smaller banjo bolt. Your delete should be sandwiched between 2 washers on the smaller banjo bolt.
4. Slide 2 washers onto the larger banjo bolt. Slide the larger banjo bolt with the 2 washers onto the delete. Now slide 1 washer onto the larger banjo bolt.. Your delete should be sandwiched between 3 washers on the larger banjo bolt.
5. Install your delete onto your rack by tightening your banjo bolts.
6. It is important to make sure you do not over *tighten it. You do not want to crush the UHMW.
Questions? email us at condorspeedshop@gmail.com
My banjo bolts are on tight as hell! I have gotten a wrench I can get into the space but just can't break the nut from its death grip! Is there an easy way to access this to get more leverage? Or ideas on how to loosen it? I just want to drive my mini again! :(
Old Aug 28, 2014 | 05:07 PM
  #144
minsanity's Avatar
minsanity
Did you access the bolts from the driver side (LH) wheel well? I won't recommend going the subframe removal route, but if you have to, might as well check all bushes & ball joints along the way. Dropping subframe makes everything easy.
Old Aug 30, 2014 | 07:14 AM
  #145
Kahnfucious
I don't have this mod but if you can slip a long rod over the end of the wrench you can use that to get more leverage or take a hammer and tap the end of the wrench to get it started....sometimes the vibration and shock of a sudden blow can loosen up bolts.
Old Aug 30, 2014 | 07:37 AM
  #146
MiniManTim's Avatar
MiniManTim
So I finally got everything taken apart and put the delete on. The steering effort is definitely easier than with a dead ps pump, parking is difficult and emergency maneuvers can get sketchy while getting used to having it on. It definitely takes some getting used to but has been fun so far. Someone earlier said it's like a 3-4 on the scale and I agree. I will continue driving with it to see how it feels.
Old Aug 30, 2014 | 08:11 AM
  #147
minsanity's Avatar
minsanity
Grats, Tim. Thanks for sharing. Get used to it 1st & let us know if it'll grow on you. Your MINI has a few parts less to worry about now. No more leaks; batt discharges due to stuck pump; fire risk; pricey pump/hoses/fan expenses.......
Old Sep 18, 2014 | 09:59 AM
  #148
jskeith111's Avatar
jskeith111
"then flip it over"
When you say take off the two 10mm bolts, and disconnect positive cable and then flip over the fuse box, I can't flip over my fuse box. There are cables running into the bottom of it that prevent me from lifting up the box to flip it. Pardon my "noobness" as I have never had to remove this front fuse box before. Is there something that I am missing here?
*EDIT*
I was able to tilt the box up to where the bottom of the box was facing the windshield. I could not flip the box completely over. This allowed just enough room to fit a torx screw in there to pull the 100A fuse.
Old Sep 18, 2014 | 06:35 PM
  #149
Da_Ghost's Avatar
Da_Ghost
*EDIT*
Yeah, that's what I meant by "flipping" it over. You can only get it pointing straigth up, but it gives you enough space to reach it.
Old Mar 14, 2015 | 07:24 AM
  #150
Jeffsmashkot's Avatar
Jeffsmashkot
I had my mechanic put this in yesterday instead of replacing the pump. I know it's supposed to be harder, but did he do it right?
Looking at the wheel as if it were a clock, I can go from 12 to 1-2 and 12 to 11-10 fairly easily. Anything past that, and it's really tough to turn. I almost want to say it was easier with the dead pump in. Could there be too much fluid in the rack still, or is this how it's supposed to be?
