R50/53 R53 manual transmission leak.
Old Mar 28, 2014 | 04:37 PM
Tora-blitz's Avatar
Tora-blitz
I have a 06 mini cooper s and my seal around the clutch rod, where it goes into the transmission is leaking. Dealer says that they dont list a seal there. so what am i supost to do. im a mechanic and do all my own work on my car. but if i cant find the part do they expect me to replace my entire transmission due to this leak? Has anyone have the same issue or have an idea? im not paying the dealer to look at my car to tell me the same thing. i work for a dealer and know how the business works.
This is the diagram from mini parts department. they say number 5 is a nylon bushing and it really is as the dealer showed me the part in person.
Old Mar 28, 2014 | 04:59 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
So they said a seal was leaking transmission fluid then showed you the fork lever bushing....
I am confused.
Old Mar 28, 2014 | 05:24 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Nope. He said that he saw the Clutch Rod leaking, went to the dealer and they said there was no seal in there. Fact is, there should not be fluid behind the fork.
///Rich
Old Mar 28, 2014 | 06:50 PM
ERIK06MCS's Avatar
ERIK06MCS
Are you sure you're not confusing this with a slave cylinder leak? It will cause wetness around this same area. Will be same color as brake fluid where trans fluid will be about black.
Old Mar 28, 2014 | 07:01 PM
Tora-blitz's Avatar
Tora-blitz
Yes i know its not the slave cylinder as that was the first thing that i checked. i wanted to make sure that it wasn't the cylinder.
minicoclub
Nov 11, 2015 07:25 AM
FrostyFox
Oct 28, 2015 02:06 PM
theblackfalcon
Oct 11, 2015 09:49 AM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
IstanBucket
Aug 8, 2015 02:25 PM
