R50/53 Remove brake reservoir strainer...how?
Old Feb 19, 2014 | 06:35 PM
juanpablo2002's Avatar
juanpablo2002
Getting ready to bleed my brake system, and all the books say to remove the brake fluid from the brake reservoir. But, how to remove the strainer to gain access to the fluid??
Looked and can't see how to remove it. I even got a special tool, turkey baster, to remove the fluid.
I'm sure its simple, therefore please enlighten me.
Humbled,
juanpablo2002
Old Feb 19, 2014 | 07:41 PM
Stoker's Avatar
Stoker
It's a ring thats kinda tight in the neck of the res. Just pull it out. A pair of long nose pliers (or your fingernails) on one side ought to do it.
Old Feb 19, 2014 | 08:37 PM
juanpablo2002
Stoker,
This is for a 2002 Mini S. I can see a plastic ring of some sort, but the reservoir neck appears to be grooved, thus the ring may not have a means to grab it. I suppose I could force the strainer over, but I don't want to break it or the reservoir.
Am I making something hard out of something simple?
Juanpablo2002
Last edited by juanpablo2002; Feb 19, 2014 at 08:37 PM. Reason: spelled name wrong
Old Feb 20, 2014 | 12:15 PM
juanpablo2002
I carefully bowed the strainer back and, with a magnifying glass, the ring is integrated into the neck.
The integrated ring has an opening. The strainer has 4 dimples. Aligning a dimple with the opening, and using a small screwdriver the strainer can be removed by bowing the strainer in so other dimples clear.
Nonetheless, this does stress the strainer. Not a good design.
But, I know how to do it.
juanpablo2002
Last edited by juanpablo2002; Feb 20, 2014 at 12:17 PM. Reason: misspelled word, shorten sentence
Kimolaoha
Jul 5, 2023 01:04 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
minipopkart
Aug 13, 2015 05:22 AM
