R50/53 Can a mini be tuned with 750cc injectors?
Old Nov 25, 2013 | 06:51 PM
astroBlackMetallic_Mini's Avatar
Found these, read here that the genesis had the same injectors. Was wondering if there was a "too much" when I came to injector size.
Would there be a benefit with going to these 750s over the 550s? (supposing they fit). The price is similar, and if your going to tune anyway, why not have more available fuel?
http://www.ebay.com/itm/New-Bosch-750cc-ev14-Hyundai-Genesis-Coupe-2-0T-turbo-fuel-injectors-Direct-Fit-/200989159973?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ecbe33225&vxp=mtr
Old Nov 25, 2013 | 06:56 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Not on an OE ECU, or without a return system.
Old Nov 25, 2013 | 11:37 PM
BlwnAway's Avatar
BlwnAway
+1, also no need for something that big unless you're doing a "Monster" build (400+) or a 275+ build on e-85.
Old Nov 26, 2013 | 05:12 AM
ZippyNH's Avatar
ZippyNH
When "huge" injectors are scaled down too far, the idle tends to be pretty bad...
Frankly I am amazed that 550's run as well as they do in a mini.
Old Nov 26, 2013 | 05:29 AM
CFMINI's Avatar
CFMINI
I have 1000 cc injectors on my MINI with a Vi-Pec ECU - idles just fine.
Old Nov 26, 2013 | 05:36 AM
DICKS GARAGE R53
Originally Posted by ZippyNH
When "huge" injectors are scaled down too far, the idle tends to be pretty bad... Frankly I am amazed that 550's run as well as they do in a mini.
All depends on who scales the tables in the ECU, and if that ECU and fuel system is even capable of running them... Stock Bosch Siemens cant really go bigger than the 550's without a trade off of issues.
iggi
18
Feb 9, 2026 01:00 AM
Aug 10, 2015 02:03 PM
M7Speed
Vendor Group Buys
Aug 10, 2015 12:32 PM
