R50/53 squeak coming from serpentine belt
Old Sep 22, 2013 | 01:46 PM
carguy123david's Avatar
carguy123david
Hi everyone I have a 05 s and it started having a terribly loud squeak coming from the belt area. Can anyone give me suggestions on what it might be. It has a alta 15% pully. squeaking starts when applying gas
Old Sep 22, 2013 | 02:11 PM
GreekDrifter91's Avatar
GreekDrifter91
could be your belt slipping, can you see how many holes are visible on the tensioner? does it smell like hot rubber a lot of the time? do you know how much boost you are seeing? how long have you had your pulley?
Old Sep 22, 2013 | 09:56 PM
AlexQS's Avatar
AlexQS
^^ + 1 -Check that stuff.
Old Oct 1, 2013 | 08:12 PM
ED955S's Avatar
ED955S
belt
Old Oct 1, 2013 | 09:09 PM
ZippyNH's Avatar
ZippyNH
Sounds like the belt is too long....90% chance a new, shorter belt will fix it....
The other 10% of items would be things like pulley was not put on tight enough, poor belt/pully alignment...even a bad tensioner....or bearings on a pulley...
So do the simple, MOST COMMON stuff first...the belt....
johntotah94
Electrical
Aug 21, 2015 01:52 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
