R50/53 OEM vs. aftermarket
OEM vs. aftermarket
I need to replace the front right side panel (or fender) on my Mini. The new OEM part is more than $200. I found one in a salvage yard for $75. However, I have also found an aftermarket panel for $50. Is there really a difference?
For what it's worth, the salvage part is the same color as the car at this time, but I am thinking about painting the entire car at a later date.
That depends...
Aftermarket parts are all over the map with respect to quality and fit. Unless you know what you're looking at, you might get a piece of crap. $200 actually sounds pretty good for a new OEM part. If that's too dear, I'd go with the used part - if it looks good inside and out.
If you cannot find an good one in the junkyard ( not rusted or damaged ) , we have the Genuine MINI side panels right here. These will line up correctly.
Side Panel Front - Right
http://www.ecstuning.com/Search/SiteSearch/41217037438/
Side Panel Front - Left
http://www.ecstuning.com/Search/SiteSearch/41217037437/
Thanks and good luck.
It's true that the aftermarket parts don't usually fit as well as the OE, but sometimes the savings is worth it.
I actually have some of those quarter panels used from wrecked cars if you want to get one from us we sell them for $65, too bad I don't have one already indi blue for you.
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
blackie
Oct 2, 2015 07:41 PM
