R50/53 Hand brake separate from disc brakes?
Old Aug 21, 2013 | 10:27 AM
devenh's Avatar
devenh
Is the hand brake a separate system from the disc brakes or does the hand brake use the disc brake system?
Old Aug 21, 2013 | 10:32 AM
cerenkov's Avatar
cerenkov
My hand brake uses both rear discs. It's attached to each caliper.
Old Aug 21, 2013 | 11:14 AM
The handbrake connects to the rear brake caliper which then puts a hold on the disc brakes.
Here is the kit for the cables, #8 and #9 in the diagram.
http://www.ecstuning.com/Search/SiteSearch/34406777400KT/
Then the cable hooks to the back of the rear caliper on each side.
Old Aug 21, 2013 | 05:29 PM
Da_Ghost's Avatar
Da_Ghost
It uses the disc brakes. Like many other cars, the piston in the rear caliper have a threaded shaft in the middle, so when you use the handbrake, it pushes the piston against the brake pad by moving the shaft. When you brake, it uses the brake fluid to push it.
Colt45Magnus
Aug 27, 2024 05:03 AM
schwac2
Jun 14, 2016 04:06 PM
Gremothra
Sep 9, 2015 08:42 PM
wildwestrider
Sep 4, 2015 06:25 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
