R50/53 lug time.... have questions tho
Old Aug 19, 2013 | 01:02 PM
tragedybysyntax's Avatar
tragedybysyntax
so my r53 is getting a revamp... ordered the lug conversion kit for the hubs. I'm looking for an aluminum red lug but I don't know to get closed or open... short or long. any tips or direct links / ideas?
Old Aug 19, 2013 | 02:57 PM
quikmni's Avatar
quikmni
What conversion kit did you order? Is it a lug bolt to stud conversion? If studs, what is the size; diameter, pitch, and length? Do you use wheel spacers, if so what thickness?
Old Aug 19, 2013 | 03:28 PM
ZippyNH's Avatar
ZippyNH
Which rims you get matter too...some rims need tuner lugs (smaller, non std shapes).
General info...
If you got std length studs, closed end is OK...
But if you got longer studs, you will need open ended....
v10climber's Avatar
v10climber
How often do you swap wheels? I like open lug nuts since my studs are fairly long. However, if you're not going to be swapping wheels every weekend try to stick with closed end studs since they'll prevent the open-ended lug from rusting onto the stud. Steel lugs are by far the most durable but the aluminum ones tend to be the blingy colored ones so you might be stuck with aluminum if you're looking for red. Also, which wheels are you running because some wheels (like motegis) require skinnier "tuner lugs".
Old Aug 19, 2013 | 05:16 PM
tragedybysyntax
http://www.malaysiaminilover.com/ima...ic-package.jpg
these are my wheels...
the kit i got was from a stud to a lug bolt convo kit from evasive motorsports.
patsum
26
May 29, 2021 06:29 PM
donniedarko
Oct 21, 2015 01:15 PM
Panik
Sep 9, 2015 08:36 AM
