R50/53 A quick question regarding timing chain tensioners
I am in the middle of changing the head gasket on a 2003 Base Cooper (no supercharger).
Do I have to remove the ENTIRE timing chain cover, to loosen the bottom bolts holding the chain tensioners?
The Bentley Manual shows a picture of the engine with the timing cover OFF, arrows pointing to top and bottom bolts, but does not explicitly state to take the whole cover off.
Are they accessible by removing the serpentine belt tensioner? Thank you very much!
I figured it out. There are NO bottom "bolts", the chain guides slide right out when top bolts and cam gear are removed! The fixed guide (intake side of engine) has a channel that slides onto a post, the other side rests on the tensioner.
09R56
Nov 16, 2022 10:49 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
