R50/53 Spark Plug Wire R&R Help
Old Jul 18, 2013 | 01:03 AM
rennwerkes's Avatar
rennwerkes
I was reading somewhere that the "flap" on the spark plug boots are supposed to form a seal to the valve cover when connected to the spark plug.
However, mine allow for a small (about 1/4") gap between the valve cover and the flap.
When I install the plug connectors all have a nice "snap" or "click" when engaging the spark plug.
I'm using stock wires and NGK plugs.
Am I missing something here?
Thanks!
Old Jul 18, 2013 | 12:40 PM
They should set flush. Push down all the way on the top of the boot to make sure.
What NGK plugs are you running ? Stock.
MINI plug wires.
http://www.ecstuning.com/Search/SiteSearch/12127513032/
Old Jul 18, 2013 | 02:35 PM
rennwerkes's Avatar
rennwerkes
Yes, using all stock parts.
So am I to assume that even after the connector snaps into place I should push down even more?
Old Jul 19, 2013 | 05:00 PM
baznight's Avatar
baznight
Is this happening on all the plugs or just one of them? If its all of them I would say you have the wrong plugs honestly.
Old Jul 19, 2013 | 07:05 PM
rennwerkes's Avatar
rennwerkes
Happening to all plugs.
I'm using the factory type NGK's and have measured them again the originals and both are the same height.
I wonder if I'm doing something obviously stupid???
But as I said before, all connectors snap in nicely.
Do I push down even more after that???
Old Jul 19, 2013 | 08:37 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
is the car running fine like this?
I would think if it's just the wires not down it would misfire.
Old Jul 19, 2013 | 10:34 PM
rennwerkes's Avatar
rennwerkes
Yup, car is running fine
eliseo1981
May 10, 2016 05:19 AM
rob76turbo
Sep 15, 2015 10:11 AM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Sep 4, 2015 03:56 PM
Sep 2, 2015 09:05 AM
