R50/53 A/C fully charged but not very cold
Old Jul 10, 2013 | 02:51 PM
PinkLinc's Avatar
PinkLinc
My 2002 has never had the coldest A/C. It's also never had refrigerant added. Phoenix is especially hot this summer so i figured I'd try to add some refrigerant and hopefully improve the situation. I bought one of those cans with the gauge and hose already attached and when I hooked it up, the needle was at the far end of the green showing a fully charged system. Is my A/C system just not up to dealing with 115 degree temperatures or could there be something else?
FYI- I replaced the power steering cooling fan last year so that's not a concern here.
Old Jul 10, 2013 | 07:29 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Have you changed your Cabin Air Filter in the last year? It makes a BIG difference if it is dirty.
///Rich
Old Jul 10, 2013 | 08:08 PM
04_Indi_Mini_S's Avatar
04_Indi_Mini_S
Originally Posted by rich.wolfson
have you changed your cabin air filter in the last year? It makes a big difference if it is dirty.
///rich
^ +1
Old Jul 11, 2013 | 04:42 AM
JoeGravelle's Avatar
JoeGravelle
I wouldn't trust those "gauges" that come with the refil kits. To properly diagnose any HVAC system home or automotive the proper high/low side gauges are needed to see the pressure in the system.
Old Jul 11, 2013 | 05:53 AM
bmwr606's Avatar
bmwr606
i have an 03/2012 build cms all4 ... many cm owners are complaining about weak A/C
if i keep the rpm above 3,000, i get 42F air out the vents on a 100+F and very humid day
if i let the rpm drop to 2,000 rpm, i get 70F or higher air at the vents
the R134A A/C systems are not as efficient as the older R12 systems were and the extra rpm helps a bunch
scott
Old Jul 11, 2013 | 07:46 AM
PinkLinc's Avatar
PinkLinc
Thanks for the responses guys. I never thought about the cabin filter affecting A/C performance. I have a fresh one out in the garage. Will give that a try and report back.
minimofo
Sep 30, 2015 12:26 AM
gmonde
Sep 28, 2015 05:22 PM
Sep 8, 2015 11:37 AM
OutMotoring
Sep 8, 2015 06:27 AM
doug5g
Sep 2, 2015 04:53 PM
