R50/53 Need Help (Colorado)
Old May 29, 2013 | 12:37 PM
Rickcolina3's Avatar
Rickcolina3
So I found out, from the mini dealer that, they have to do $4000 worth of repairs (clutch plate, coolant leak, brake flush,and something that has to do with the front end of the car) I am a student and have no where near $4000 to drop on a car that I've had 4 months. Is there anyone in colorado that can help me out?
Old May 29, 2013 | 12:47 PM
cooperScaleb05's Avatar
cooperScaleb05
Since yours doesn't have a warranty I would not use the dealer. I found this website a little while ago and it has seemed to be pretty useful. http://soopercooperinfo.com/lindaminiinfo.html
Old May 29, 2013 | 01:07 PM
old81's Avatar
old81
M6
Rick,
A couple of independent MINI shops are in Denver, Ferney's on South Santa Fe and Peak Eurosport in Westminster.
The clutch in the MINI Cooper is not a cheap item to replace, labor is expensive. I suggest you shop around.
Old Jun 14, 2013 | 01:49 PM
Melissa@Ferneys's Avatar
Melissa@Ferneys
Hi Rick,
Were you able to get these repairs taken care of? If not, it might be that Ferney can work with you a bit as to price, etc. Shop location and phone are at www.ferneyslubeandauto.com. If you you've got everything all set, I hope you are enjoying your driving! Best wishes to you in either case.
Old Jun 14, 2013 | 02:41 PM
Mib4840's Avatar
Mib4840
If your coolant leak is at the tank it is an easy fix you could do yourself. Coolant tank and a cap are about $75 and it takes 2 bolts/nuts and a hose clamp removal to fix it. The brake flush is almost always recommended when you take a vehicle to the dealership, you could probably hold off on that. What is the front end doing, squeaking, clunking, pulling to one side, etc...? Clutch is a different story. Search the forums for clutch, I remember seeing some posts that described certain problems that were annoying due to the sound but did not affect the drivability and could be put off for a short period. It could buy you some time to fix them one at a time and give you an idea of which one to do first. Good luck.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
sleek55044
Oct 14, 2016 01:52 PM
sleek55044
Apr 21, 2016 07:05 PM
kohlersc
Sep 28, 2015 09:49 AM
Racingguy04
Electrical
Sep 15, 2015 06:19 AM
