R50/53 ABS Issues help!
Old May 7, 2013 | 08:16 PM
JVCOBRA's Avatar
JVCOBRA
ABS Issues help!
Having trouble with my 06 Cooper S ABS system. Ever since I have owned this Mini the ABS has not worked. I had it diagnosed that the front wheel speed sensor is where the problem was. After replacing the sensor the ABS lights will be off and stay off when you first start the car and once you take off and hit the brakes, though the wheels are not slipping, the ABS will activate and the lights will come back on. It looks as though the drivers' axle has been replaced so I am wondering if whatever the ABS sensor is sensing could be the issue. Any help or knowledge about how the ABS system works on R53s is much appreciated.
Old May 9, 2013 | 10:30 AM
JVCOBRA's Avatar
JVCOBRA
Any ideas guys?
Old May 9, 2013 | 11:57 AM
Braminator's Avatar
Braminator
When you drive and slam on the brakes is the ABS doing its job?
Old May 10, 2013 | 09:57 AM
JVCOBRA's Avatar
JVCOBRA
The ABS does not activate.
Old May 10, 2013 | 10:06 AM
Braminator's Avatar
Braminator
Then you abs pump and/or module is not working.
Old May 10, 2013 | 10:09 AM
JVCOBRA's Avatar
JVCOBRA
It pumps when I first start the car and hit the brakes though.
Toolman
Jan 20, 2016 06:50 AM
LordOfTheFlies
Oct 19, 2015 05:02 PM
bansasn
15
Sep 4, 2015 01:24 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
1964geo
Aug 10, 2015 06:22 AM
