R50/53 Which fuse is headlight washer on 02 Mini?
Old Mar 26, 2013 | 02:05 PM
champagne4amy's Avatar
champagne4amy
Well the cover for my headlight washer came off and I tried to replace it but it just came off again. I want to disable the headlight washers completely so I can put the cover back on it and not have this annoying big gapping hole. I have tried to do a bit of research as to which fuse it is that controls the headlight washers but am getting frustrated. I figured someone on the forum might know the answer right away. It is a 2002 Mini Cooper R50.
Old Mar 27, 2013 | 08:56 AM
Did you try a new headlight washer cover ? If you did the connection at the end on the actual headlight washer jet to washer cover might be broken. You can see the end connection on the washer jet in the picture towards the left hand bottom. Check that connection out. Which side did you have the problem on?
Here are the parts.
Headlight washer jet: Right ( passenger side )
http://www.ecstuning.com/Search/61677147046/ES170583/
Headlight washer cover: Right ( passenger side )
http://www.ecstuning.com/Search/63126922156/ES172796/
High Pressure Jet Headlight Washer - Left ( driver side )
http://www.ecstuning.com/Search/61677147047/ES170584/
Headlight washer cover: Left ( driver side )
http://www.ecstuning.com/Search/63126922155/ES172795/
Thanks and I hope that helps.
Old Mar 27, 2013 | 10:18 AM
champagne4amy
I did try another cover but when the headlamp washer was used it popped the cover off again. It is the driver's side that I am having trouble with.
Old Mar 27, 2013 | 10:42 AM
The driver side washer jet near the sprayer has a built in little clip that comes with the whole part. I bet that's what is broken since the new cover did not work. Check that out and compare it to the pics. I bet that is your problem.
Old Mar 27, 2013 | 11:07 AM
Braminator's Avatar
Braminator
Maybe this will help.
Engine compartment fusebox
F1 5A Digital engine electronics control unit
F2 20A Digital engine electronics control unit/Ignition coil/Cylinder 1-4 fuel injection valves/Crankshaft position sensor (From K6300 87)
F3 15A Camshaft position sensor/O2 sensor before cat/O2 sensor after cat/Solenoid valve, fuel tank ventilation/Relay K19 control power (From K6300 87)
F4 15A Tank Leakage diagnosis pump
F5 5A Relay, engine cooling electric fan (From K6300 87)
F6 30A ABS/ASC/DSC control module
F7 30A Magnetic clutch for AC compressor via relay K19
F8 30A control power K69923 Relay, electric power steering pump cooling fan/Switch unit Heating & A/C blower
F9 20A BC1 (X11177 2) unit via I01136 and I01137 (Relay front wiper motor fast/slow and Relay front wiper motor on/off)
F10 15A BC1/Left fog/Right fog/Switch panel via K47
FL1 50A Feed to F14, F31, F32 (BC1,Heating & Air con blower)
FL2 50A Feed to F1, F2, F3, F4, F19, F20, F21, F22, F23, F24, F25, F26, F27, F28, F37 (BC1, steering angle sensor, clock, instrument cluster, navigation, on-board monitor, wash/wipe, horn, audio system.)
FL3 -
FL4 100A Electric Steering control unit/Hydraulic pump
FL5 50A Feed to F15, F16, F17 (Sunroof, aerial antenna, rear wiper)
FL6 40A ABS/ASC/DSC unit
FL7 50A Feed to ignition switch
FL8 50A BC1 (X332 20) Headlight
FL9 50A DME unit and Switching unit 2-speed blower via I01135 (Relay electric engine cooling fan)
FL10 50A K416, Relay heated front screen
FL11 50A Switch unit, 2-speed blower heating & air con
FL12 50A BC1 (X332 17) Headlight
Passenger compartment fusebox
F1 30A BC1 (X332 3) power windows LH
F2 5A Steering angle sensor
F3 5A Digital clock/Outside mirror fold-in control unit
F4 5A BC1 (X254 27) Constant power
F5 5A Control module for instrument cluster/Diode (From Electronic immoblizer control unit)
F6 5A Brake light switch/Clutch switch module/Electronic immobilizer control unit EWS
F7 5A BC1 (X254 36)/Rain sensor
F8 5A Turn indicator/low beam switch
F9 5A Control module for instrument cluster
F10 5A Navigation computer/On-board monitor control unit/Radio control unit
F11 5A K119, Relay, rear washer pump/K5 Relay, front washer pump
F12 20A Ignition switch to heated seats
F13 5A Reversing light switch/CVT switch
F14 10A BC1 (X332 14) Constant power to interior/reading lamps
F15 20A Sunroof module control unit
F16 30A BC1/Rear window w/o antenna or Wave trap 1 w/ rear window antenna via K13/ Heated rear screen
F17 15A BC1 (X254 43)/Rear window wiper motor via I01142 (Relay rear wiper motor)
F18 5A Hall sensor driver & passenger buckle/Multiple restraint system (SRS system)
F19 30A BC1 (X332 7) power windows RH
F20 20A K96, Fuel pump relay 1
F21 10A Control module for instrument cluster
F22 15A On board monitor control unit/Navigation computer/Eject box
F23 20A K5 Relay front washer pump/K119 relay rear washer pump
F24 5A Electronic immobilizer control unit/Horn for antitheft alarm system EWS
F25 30A Headlight washer pump via K6
F26 10A Automatic transmission
F27 15A Radio control unit/CD Changer/Amplifier
F28 15A Volute spring/Right horn/Left horn via K2
F29 5A Heating and AC control module/Sensor interior temperature fan
F30 5A Instrument cluster
F31 30A BC1 via K4 (X253 23) Heating & A/C blower
F32 15A Front cigar lighter via I01151 (Relay cigarette lighter front)
F33 10A ABS/ASC/DSC unit
F34 10A Digital engine electronics control unit direct and via K96/Eng management main relay
F35 5A Mirror adjustment switch/Electrochrome rear view mirror/Windscreen washer jet heater/Outside mirrors
F36 5A K416, Relay Heated front screen
F37 20A BC1 (X332 1) Central locking
F38 -
F39 5A Alternator/Electric Steering control unit/hydraulic pump
F40 5A Control module for instrument panel/Switch panel/Steering angle sensor
F41 5A Park distance control unit/power to K69923, Relay fan steering control module/pump
F42 -
(MCS Only – Luggage compartment fusebox, MC/One direct battery feed)
F100 250A Feed to FL1, FL2, FL4, FL5, FL6, FL7, FL8, FL9, FL10, FL11, FL12, F1, F6, F7, F8, F9, F10, K6300
For Ref.
BC1 – Body Control Unit
Located behind kick panel – drivers footwell (UK) / passengers footwell (USA / Europe)
4 Connectors:-
X332 20 pin (green)
X253 54 pin (black)
X254 54 pin (natural)
X255 54 pin (blue)
IDs for Relays / Location
K2 Fanfare Horn relay / Passenger compartment fusebox
K4 Heater-blower relay / Engine compartment fusebox
Control: BC1 (X253 23)
Switch: M30/A11
K5 Relay washer pump front / Behind passenger compartment fusebox
K6 Relay Headlight washer / Passenger compartment fusebox
K13 Relay rear window defroster / Passenger compartment fusebox
Control: BC1 (X254 22)
Switch: Rear window defroster
K19 Relay AC Compressor / Engine compartment fusebox
K47 Front fog light relay / Engine compartment fusebox
Control: BC1 (X254 40)
Switch: Left fog light/Right fog light/Switch panel light
K96 Fuel pump relay / Passenger compartment fusebox
Control: A6000 (X60004 24)
Switch: M2
K104 Relay auxiliary water pump
K119 Relay washer pump rear / Behind passenger compartment fusebox
K416 Relay heated windshield
K6300 DME Relay
control: A6000 (X60004 16)
Switch: F02/F03/F04/F05
K69923 Relay fan steering control
Relay front wiper fast/slow / Engine compartment fusebox
Relay front wiper on/off / Engine compartment fusebox
Relay rear wiper / Passenger compartment fusebox
Relay cigar lighter / Passenger compartment fusebox
Old Jul 7, 2024 | 04:08 AM
Broffrey's Avatar
Broffrey
Left-hand drive driver / Right-hand drive passenger footwell fusebox
I confirm, but also check / replace this relay plugged just right side to the F27 to to F29 fuses:
milkrun49
Factory JCW Talk (2009+)
Aug 13, 2015 06:01 AM
ludedude
Aug 10, 2015 07:16 PM
nismo4life
Aug 5, 2015 08:31 AM
