R50/53 brake fluid change.
Old Mar 19, 2013 | 06:31 PM
GreekDrifter91's Avatar
GreekDrifter91
brake fluid change.
how much do i need tried lloking around and i see all you need to do a full flush is 500ml then i see you need 1L so how much do i need? how much do i need if i am flushing the clutch too?
Old Mar 19, 2013 | 06:39 PM
Braminator's Avatar
Braminator
One liter will be good enough for a bleed but for a complete flush, 2 liters flushed through should be more then enough to flush it complete. I would use a pressure bleeder to do it. Thats just my opinion.
Old Mar 19, 2013 | 06:59 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Concur...1 liter should do it but, tread cautiously and study up b4 you attempt to bleed the clutch slave cylinder. Do it wrong and you'll go through 2 or 3 liters trying to get the air out. The slave piston has to be fully compressed and kept that way while you are bleeding.
Old Mar 19, 2013 | 07:01 PM
GreekDrifter91
ok i bought 2L of super blue, if i dont need all of it ill just leave whats left over for next time or for something else.
Old Mar 19, 2013 | 07:15 PM
Braminator's Avatar
Braminator
Well now you just started something. You are most likely going to hear lots of positives and negatives about this fluid. I have been using it in many cars including my MINI for 2 years with no issues. Others have said they had issues with it ruining seals. So I guess time will tell with yours and I hope you have good luck like I have had.
Old Mar 19, 2013 | 07:23 PM
GreekDrifter91
im sure i will be fine i tend to draw the long stick when these types of "issues" come up lol
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
Gremothra
Sep 9, 2015 08:42 PM
wildwestrider
Sep 4, 2015 06:25 AM
Ntety
Sep 2, 2015 08:39 PM
elightbo
Sep 2, 2015 08:17 AM
