R50/53 Accessing belt tensioner and cam sesnor
Old Mar 17, 2013 | 06:57 PM
Grahams315's Avatar
Grahams315
Hey guys, I finally got my tensioner/belt/belt tool and replacement O-rings for the cam position sensor to hopefully fix a leak but i have a question i haven't been bale to resolve.
I know i will have to remove the upper passenger side engine mount to raise that side of the engine up. However, do the other mounts need to be loosened or removed to gain enough clearance? The info I've read says anything from loosening the transmission mount and leaving the lower mount, to completely removing both (which sounds kind of sketchy).
Has anyone done this or something similar and can give me some insight onto what mounts have to come out?
Old Mar 18, 2013 | 05:39 PM
Grahams315's Avatar
Grahams315
Bump. I'm hoping going to work on this tomorrow but I'm nervous about having all three engine mounts undone at the same time
Old Mar 18, 2013 | 05:44 PM
Braminator's Avatar
Braminator
Yes you should do this to have more access http://www.pelicanparts.com/techarti...eplacement.htm
Old Mar 18, 2013 | 05:53 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
May I humbly suggest that you first put the front end up on jackstands, remove the passenger side tire and wheel, then the plastic wheel well liner and see what you've got. As I recall, I've been able to access the belt tensioner w/o raising the engine. If need be, you can always do so.
Old Mar 18, 2013 | 05:57 PM
Braminator's Avatar
Braminator
LOL. Thats all part of the instructions and yes you can do it that way. But to have greater room for someone new, it is sometimes easier to jack the engine up IMO.
elverado
Jan 18, 2022 02:51 AM
patsum
26
May 29, 2021 06:29 PM
Vaderm34
Sep 27, 2015 09:25 PM
hong
Sep 13, 2015 06:41 PM
Emnotek
Sep 11, 2015 04:16 PM
