R50/53 No Start R53 with interesting side effects
Old Jan 23, 2013 | 08:28 AM
sijeffery's Avatar
sijeffery
So this morning I go to start my trusty MINI and all I get is clicking of the starter with my high beams flashing and the drivers window lowering about an inch with every click. Any ideas on what may be going on?
Old Jan 23, 2013 | 08:38 AM
xsmini's Avatar
xsmini
I would guess battery. Weird things happen when the battery goes.
Nik
Old Jan 23, 2013 | 08:43 AM
kromdom's Avatar
kromdom
agree with the battery as primary suspect. take it to your local auto parts store and have it LOAD-TESTED. If it fails, buy a new one.
Old Jan 23, 2013 | 08:55 AM
sijeffery's Avatar
sijeffery
Thanks for the quick responses. I should have prefaced that last Wednesday a Ford Explorer tried to make my MINI his hood ornament and at the moment I am not able to get easily to the battery compartment.
Old Jan 23, 2013 | 09:00 AM
xsmini's Avatar
xsmini
That will cause weird things too! Maybe the reason the battery is dead?
Nik
Old Jan 23, 2013 | 11:05 AM
area49's Avatar
area49
Occams Razor:
Of all possible explanations,
the simplest is usually correct.
Electrical issue(s) most likely related to recent impact.
Assess damage or you could end up with a fire back there if the + batt cable goes to ground.
(if batt is located in back, as in MCS),
Old Jan 23, 2013 | 11:07 AM
ZippyNH's Avatar
ZippyNH
Nik
Sudden impacts can cause the lead plates to break, or the plastic case to crack....leading to leaking battery acid...both lead to a dead battery...one much more dangerous than the other...then again...a partially cut or dammaged battery cable can arc, causing a fire or lack of current in sufficent amps to crank....
I would inspect it asap.
iggi
18
Feb 9, 2026 01:00 AM
cm.d
Aug 19, 2015 08:51 AM
Emnotek
Aug 13, 2015 05:47 PM
