R50/53 Installing Powerflex Complete Engine Bushing Set
Old Feb 25, 2014 | 10:26 AM
  #51
RA082324's Avatar
RA082324
so, just to get rid of any confusion here... taking a look at this diagram:
http://realoem.com/bmw/showparts.do?...66&hg=22&fg=05
i am under the impression that the TSW and VT mounts, would be replacing #4... while the PF inserts would be an addition to #8?
and then the lower mount is #11? which VT and BSH make replacements for, as well as the PF inserts?
again i am a 4/03 model if it makes a difference.
Old Feb 25, 2014 | 10:38 AM
  #52
IQRaceworks's Avatar
IQRaceworks
Yes, I think you have it right. #4 in the 03' cars is not fluid filled like the 04+ cars....and I've heard they are more durable. Mine looked fine after 120,000 miles....so I just left it. The PF bushings really firm everything up....I don't really know why the TSW or VT mounts would be any better...they just cost more. Just go with the full PF kit for the 03' R53s...it's got everything you need. Way Motorworks sells the kits.
Old Mar 13, 2014 | 08:04 AM
  #53
RA082324's Avatar
RA082324
anybody ever find a how to for the upper mount inserts?
Old Mar 13, 2014 | 09:37 AM
  #54
IQRaceworks
The upper mount insert is easy.....remove the bracket, slide in inserts, reinstall bracket.....done.
Old Mar 13, 2014 | 10:14 AM
  #55
RA082324's Avatar
RA082324
i bought the large and small inserts for both upper and lower. hopfully it goes smoothly.
Old Mar 13, 2014 | 01:03 PM
  #56
RA082324's Avatar
RA082324
Upper was not as smooth as expected. I'll see about the lower tomorrow.
Old Mar 19, 2014 | 09:29 PM
  #57
Kimbo80's Avatar
Kimbo80
I have the lower engine bushing (main, large yellow bushing) and am impressed for such a cheap mod. Does the smaller lower engine bushing (purple) make a noticeable difference, or is it relatively minor?
Old Mar 20, 2014 | 01:19 AM
  #58
RA082324's Avatar
RA082324
i have no comparison. i did the large and small on both upper and lower.
what i can say, i do like it, and actually wouldnt mind if they were even a little stiffer. its all personal preference though.
also, when doing the small ends, youre going to have to hammer the old bushings out, since they are complete replacments. so theres no going back without buying new oem if you dont like it. i like mine though.
Toolman
Jan 20, 2016 06:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
minipopkart
Aug 13, 2015 05:22 AM
O4mcs
Aug 10, 2015 10:22 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
