R50/53 Rain Sensor Issues and Fix
Old May 5, 2012 | 03:36 PM
davsanto's Avatar
davsanto
2005 Mini Cooper. Windshield replaced - rain sensor does not work
Common issue as I searched the web for results. Most discussed the mounting of the sensor.
Well the issue was the connector. One of the pins in the connector was not connecting!. The shop put in several windshields and new rain sensors with all the same results.
So if you windshield is replaced ( and this goes for BMWs as well)
have the connector inspected to insure all the pins are good and there is good electrical contact.
It is usually the simple things that go wrong.....
Old May 5, 2012 | 05:26 PM
daflake's Avatar
daflake
In my case I could set off the wipers by tapping the windshield. All of the sensors that I got in three different cheap windshields were not glued on correctly. PGP glass was the solution with the sensor glued on correctly.
Old May 5, 2012 | 06:10 PM
davsanto's Avatar
davsanto
Yes that also seem to be a common issue with the gel mount not installed properly.
Old May 6, 2012 | 11:26 PM
works911's Avatar
works911
I have the same problem. Wheres the sensor located exactly? I got my windshield replaced by a jobber and it stopped working and I got no clue how to fix it.
Old May 7, 2012 | 04:15 AM
davsanto's Avatar
davsanto
OK First the shop that did the windshield should look into your issue. Safelite did mine and the tech worked hard to solve the problem.
The rain sensor is located directly behind the rear view mirror.
There is a black plastic cover that can be gently pull off.
The sensor is a black box that looks like the one in the picture at this link:
http://www.autopartsnetwork.com/cata...rket_make:Mini_
It is removed by sliding the two (left and right) slide pins and it pops off. Be careful not to pull the wires - It is best to remove the connector/wires first.
In my case one of the connector pins was not making contact. The tech was able to push the pin in to make contact with the sensor. This solved my issue.
I have read that other issues can be the type of glass used and how well the mounting gel is "glued" to the windshield where the sensor is mounted. I did nto have these issues.
Note the sensor also works the auto headlights...
Good luck
Old May 7, 2012 | 08:51 PM
works911's Avatar
works911
Big thank you.
Kimolaoha
Jul 5, 2023 01:04 PM
alistaircookie
Oct 8, 2015 10:52 AM
Bennyboy
Aug 18, 2015 07:28 AM
MES11
Aug 8, 2015 10:21 AM
