R50/53 2004 Auto window up
Old Mar 22, 2012 | 06:56 AM
clos8's Avatar
clos8
2004 Auto window up
I did it once and it worked and now it wont do it for my driver side window. Anybody else had this problem or a fix?
Old Mar 22, 2012 | 07:05 AM
mdsbrain's Avatar
mdsbrain
Do you have a (Ian Cull) Auto-Up circuit? Otherwise they don't Auto Up in the Gen 1 cars.
Old Mar 22, 2012 | 07:43 AM
clos8's Avatar
clos8
I dont know, But I know i did auto up once.
Old Mar 22, 2012 | 08:00 AM
ZippyNH's Avatar
ZippyNH
The auto up is an aftermarket add on....
the above mentioned module enables it...
plugs into the back of the switches...
Find the instructions, and you mightily need to reenable it...
There are several dolifferant generations of the module...the maker made them as a project..then sold a few...then more...he is a member here...sold the module and the rights/support eventually.
Old Mar 22, 2012 | 08:01 AM
zamfield's Avatar
zamfield
Try the directions of holding down the lock switch. If you hear a been, you may have it installed...
www.minimania.com/pdfile/NMA5503_INSTR.pdf
Old Mar 22, 2012 | 08:15 AM
clos8's Avatar
clos8
Ok tried it with no luck. I do see the place where there was a little LED installed. Im gonna get into the back of that and see if it is installed. I know im not tripping and I did do the auto up once.
Old Mar 22, 2012 | 08:56 AM
rkw's Avatar
rkw
What do you mean exactly when you say "did it once"? The default action for Ian Cull's circuit is a double click. Is that what you did?
Old Mar 22, 2012 | 09:13 AM
clos8's Avatar
clos8
No I pushed a single click up when I first tried it per the manual and it went auto up on the drivers side but not the passengers side.
Old Mar 22, 2012 | 10:20 AM
rkw's Avatar
rkw
What does your manual say? In the 1st gen models, MINI could not offer auto up in the US (not legal) because the window doesn't have a pinch sensor. Hence the aftermarket auto-up circuit was created. However, auto-up was legal and available in Europe. The manual may have been derived from the European copy and the editor didn't catch it (there are a few other Euro-only items mentioned in the manual, not applicable to the US).
Perhaps the switch was sticking when you tried it the first time?
Old Mar 22, 2012 | 12:08 PM
clos8's Avatar
clos8
The manual said for auto window up press once for auto up and it didnt work with the passenger window.
Old Mar 22, 2012 | 01:57 PM
rhlanham's Avatar
rhlanham
Per the owners manual, p. 28, the window on the front passenger's side cannot be closed automatically.
Reid
Old Mar 22, 2012 | 02:40 PM
rkw's Avatar
rkw
But it doesn't work on your driver's side either, does it? As I mentioned earlier, auto-up was unavailable for US spec.
I think the one time was a lucky accident.
clos8's Avatar
clos8
Reid
Yeah sorry, I wrote that wrong. Thats what I meant, the drivers side went auto up on me but the passengers didnt as per the manual. But when I tried to do the drivers auto up again, it wouldnt work again.
Old Mar 22, 2012 | 03:00 PM
Blckmorning's Avatar
Blckmorning
I've never heard of even the Driver's side auto up without the aftermarket circuit. I know it's not something you can program on the computer either since i checked on that last week when i was re-programming my module.
Old Mar 22, 2012 | 09:21 PM
clos8's Avatar
clos8
Yeah, I swear it did go auto up. I might take it apart and see if the circuit is hooked up
Old Mar 23, 2012 | 03:32 PM
stranger55's Avatar
stranger55
You can by a board or make your own component with capacitor and resistor for less than 10 bucks.
https://www.northamericanmotoring.co...p-windows.html
Old Mar 23, 2012 | 04:34 PM
Blugoose's Avatar
Blugoose
Ian Cull Auto-Up Circuit
Go to www.fes-auto.com for info or instructions.Phone is 650-332-1161. Hope you have small fingers!!
Old Mar 23, 2012 | 06:03 PM
Blckmorning
This will give you an idea of what the circuit looks like on the board.
http://www.mini2.com/forum/first-gen...agram-etc.html
Old Mar 23, 2012 | 07:16 PM
zamfield's Avatar
zamfield
I already posted a link to the instructions for Ian Cull's auto up... post#5!!
Old Mar 23, 2012 | 07:40 PM
Blckmorning
The post i did was the switch board, not Ian's circuit.
Old Mar 23, 2012 | 09:52 PM
clos8's Avatar
clos8
So I just took it apart. No Board Back there :( it seems like they might have had an alarm hooked up at some point and mad a hole there for the LED. Here is what I found.
Any Idea what would go in this slot if it was being used?
The alarm LED. Wonder If I can hook it up to light up when like say the fog lights are on.
Thanks everyone for their replies. Im gonna buy the Auto up V7 because this holding the switch up gets on my nerves especially when pulling out of drive thrus.
Old Mar 23, 2012 | 10:14 PM
rkw's Avatar
rkw
That was definitely a DIY modification. Normally it would have a blank filler cap if the position is unused with no switch (btw, that location is for the rear fog switch).
Old Mar 24, 2012 | 06:38 PM
clos8's Avatar
clos8
Went ahead and bought the FES V7 auto up.
Moshu-Clubman
R55 :: Clubman Talk (2008+)
Jul 13, 2016 08:54 AM
3L6
Sep 21, 2015 06:21 PM
Gen1Parts
Sep 7, 2015 03:50 PM
