R50/53 Cost to Replace Control Arm Bushings?
All,
I'm going to buy some Powerflex front control arm bushings, probably from Way. A few questions:
1. What is a fair labor charge for a shop to install them?
2. Should I get them pre pressed? Seems like this might save significantly on labor costs.
3. Is there anything else I should have done while I am having this work done, i.e. because the labor would kill two birds with one stone (or maybe more than two).
My MINI has 92,000 miles. I am the third owner, but the car has been meticulously maintained.
Thanks in advance for everyone's input!
Many shops will charge about 5hrs labor. Our local dealer charges $1300 do do it.
I recommend replacing the front sway bar bushings at the same time, you'll already have them unbolted.
WOW!!! $1300!!! I got quoted $400 for Labor (I think 5-6hrs), but that is a local MINI Shop, not dealer. I am going to buy Alta's PSRS which cost $280, but did find at Way Motor Works for $210 shipped.
Ps: WMW do you still have the Alta PSRS bushing in stock? I saw that you are not going to carry Alta Products anymore.
Phew! I first saw the $1,300 and thought I was in trouble. I'm going to use my local guy rather than the dealer, so I'm guessing I can keep it below $500.
I have access to a lift at my Dad's garage. Is this hard to do if you have the right setup and tools or am I better off having my local garage do it?
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
R50/53 2002 R53 Creaking/Clacking
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
