R50/53 Hood Scoop Service Bulletin
Old Feb 18, 2004 | 12:51 AM
  #26
EBMCS03's Avatar
EBMCS03
>>I tried to find the bulletin on the hood rattle, but could only find this one. If anyone wants to know if there is an open campaign on their car please feel free to contact me and I'll try to look it up.
>>Service Measure
>>Body
>>M41 200 03
>>7/1/2003
>>Subject:
>>Paint Damaged Under Hood
>>Complaint
>>Some MINI owners may complain that the paint in the area of the hood strikers is damaged.
>>Cause
>>Movement of the hood against the seal on the top of the radiator shroud can eventually rub through the paint on the underside of the hood.
>>Measure
>>Protective shields, part numbers 51 48 7 126 245/246, have been developed to prevent this paint damage.
>>If the paint has been worn through to bare metal, touch up the affected area with zinc based brushable primer.
>>Remove the screw from the expanding plastic pin that secures the hood pad on both sides. Remove the white plastic strip from the double-sided tape on the shields and install the shields between the hood pad and the hood, pressing the double sided tape firmly into place. Reinstall the expanding pins and screws.
THANK YOU!! I've told my dealer about this and they told me they know nothing... so i'm like ARGH fine!
Old Feb 18, 2004 | 08:05 AM
  #27
KeyMini's Avatar
KeyMini
Where do you get removable bonnet stripes?
Old Feb 18, 2004 | 08:09 AM
  #28
dgrinsel's Avatar
dgrinsel
Checked mine yesterday. They were loose. Mine is a 2004 with only 4500 miles. It was delivered in October, 2003. Thanks for the tip.
Old Feb 18, 2004 | 01:03 PM
  #29
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Sure enough, I checked on mine and the two nuts which attach the rearward part of the scoop are gone entirely. This probably has to do with the fact that these nuts also hold the plastic air deflector in place. The expaning and contracting of the plastic deflector no doubt made these little 5mm nuts loosen then fall off. Looks like I gotta root through my bolt bin for locking replacements.
Old Feb 18, 2004 | 01:14 PM
  #30
MaxaMini's Avatar
MaxaMini
Read this yesterday and checked I'm short the two front nuts. Still! I hasd read the original and asked the dealer on two previous visits for other issues to fix it. Stopped by dealer for other issue yesterday and printed copy of this thread given to
service advisor. Told tocome back in ten days .
I think I'll remove it and report it blew away on the interstate. I could use a spare.
Old Feb 18, 2004 | 06:46 PM
  #31
EBMCS03's Avatar
EBMCS03
>> :smile:
Old Feb 18, 2004 | 06:56 PM
  #32
pocketrocketowner's Avatar
pocketrocketowner
>>Read this yesterday and checked I'm short the two front nuts.>>
I just checked mine, they are still attached!!! My wife says barely though......
Old Feb 18, 2004 | 09:13 PM
  #33
Ryanide's Avatar
Ryanide
I checked mine after reading this post, and BOTH of mine are gone! A little tug on the scoop and yep it was loose as can be. Just sitting in place!
I'm surprised.
July 2003 build S
marendt428
Feb 25, 2016 07:13 AM
BRracing
Dec 22, 2015 09:25 AM
Aug 24, 2015 02:22 PM
rentedblackbird
Aug 24, 2015 10:22 AM
O4mcs
Aug 10, 2015 10:22 PM
