R50/53 Crank pulley and CV joints? Help, car stranded. :(
Old Jul 26, 2011 | 08:38 AM
dkellerd's Avatar
dkellerd
Hello, new member, first post...bad circumstance. :(
I was driving in Oklahoma City this past weekend in my 05 MCS when all the sudden I heard a noise and the cars' guages lit up like a christmas tree and I could see the serpentine belt hanging.
I had it towed to Jackie Cooper BMW/Mini in Edmond and they have told me I need to replace the crank pulley and the CV joints. Price they quoted was around $1500. I don't use stealerships, so I was hoping to find out from someone what I should do to get this fixed the cheapest way.
I see some crank pulleys on ebay for around $80 and some axle shafts for around $60 each.
Any help would be appreciated...are there any good mini shops in OKC area that I can trust not to screw me like a stealership? Thanks so much in advance!
Old Jul 26, 2011 | 09:43 AM
dkellerd's Avatar
dkellerd
Would it be better or cheaper to just replace the whole axle instead of the cv joints? I'm trying to find out which cv joints are bad from the mechanic...
Old Jul 26, 2011 | 10:51 AM
element's Avatar
element
with the CV joints it really depends on how bad they are.. once the grease leaks out they self destruct as they collect dirt.. you could re-build them ($60 per side for the boot+grease kit) that's what i do to mine as i want to keep the stock ones as long as possible.
I also think it's strange that someone doesnt make kevlar lined boots that last the life of a car - such a waste to keep replacing them because of a rubber boot when the metal joint could last the life of the car if it never became contaminated.
phil.
Old Jul 26, 2011 | 11:22 AM
dkellerd's Avatar
dkellerd
Where did you get that $60 per side figure? Is that for parts only or for parts and labor?
Are there 4 cv joints on the front? 2 joints per axle? I know nothing about cv joints so if you could educate me I would be forever grateful! Thanks for the reply element!
Old Jul 26, 2011 | 01:36 PM
element's Avatar
element
i just checked and the inner and outer kits are $60 each.. you need to pull both to do the work.. and i did it myself
Old Jul 26, 2011 | 08:45 PM
dkellerd's Avatar
dkellerd
Anyone else have opinions or experience with these aftermarket pullies and cv boots? Any known Mini shops in OKC?
09R56
Nov 16, 2022 10:49 AM
Toolman
Jan 20, 2016 06:50 AM
azntaiji
Aug 13, 2015 03:24 PM
Lt. Dan
Aug 10, 2015 12:46 PM
