R50/53 Fitting 4 x Hella Comet 200 lights to grill of R53 MCS
Old Sep 24, 2009 | 08:49 PM
jacknick's Avatar
jacknick
Hi all,
I am about to attempt my first mod on my newly purchased 06 MCS checkmate.
I got a great deal on 2 boxes of Hella Comet 200 driving lights (4 lights altogether). Each set comes with mounting brackets specifically designed for the Mini. What I didn't consider before purchasing was that none of the mounting brackets are ideal for mounting the 2 lights that will be nearer the middle of the bonnet.
I have tried positioning them and can make it work with washers etc. but then the lights are too close together.
I think that the only way I can make it work is if I cut out part of the black plastic which is behind the grill on the far left and right.
Any ideas?
Old Sep 25, 2009 | 11:42 AM
Capt_bj's Avatar
Capt_bj
you might mount one pair of brackets as far apart as possible and then fabricate a cross bar between the brackets allowing positioning of the lights anywhere on the bar.
or fabricate a short cross bar on each bracket allowing two lights to be mounted per bracket.
messyjesse96
Aug 12, 2015 05:51 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
