R50/53 Correct me if I'm wrong - how is this brake setup?
Old Mar 13, 2009 | 01:06 PM
  #26
LilRedMini's Avatar
LilRedMini
Originally Posted by Some Guy
That was basically my thought process too. When I pulled my front pads off they actually looked like they had a bit of life left on them, but I AutoX so I knew that as soon as the season started back up the pads would be going bye-bye. Furthermore it was something that was going to have to be done eventually, and the OEM pads were starting to feel a bit tired, so I basically said "may as well do it now".
Here is a cost breakdown BTW:
-Axxis Ultimates: $64 shipped (from ImportRP)
-Centric Rotors: $78 shipped (from RockAuto)
-Assorted tools and lube: ~$25
I did it myself, it is not a hard job to do if you have access to the tools.
I understand your situation. They were scary thin.
For everyones information though, thinner pads will provide better high performance braking than thick ones. The reason is that they can dissipate heat more readily, and when you think about it, that's what brakes do, dissipate heat. They basically convert the kinetic energy of motion to heat and dissipate it.
That is not to say that you should run pads that are almost metal to metal, but as long as they are NOT metal to metal, thin pads will offer better braking than thick pads, providing that all other factors are equal.
In addition to superior braking performance of thin pads, with thinner pads, the wear rate is slower for the same reason. Since the pad material can more readily dissipate heat, less wear will occur with thinner pads. When thicker, the pad wears away at a faster rate than when the same pad is thinner. In other words 1/16" will wear off of a near new pad much faster than 1/16" will wear off of a more worn out pad.
Old Mar 13, 2009 | 01:35 PM
  #27
22CooperS's Avatar
22CooperS
HAHA My wallet's too thick? Yep. That's why I didn't drop a grand at the MINI dealership... also why I work 2 jobs. Oh, and I'm 19. And it's my car to pay for. But I digress...
Anyways:
Decided to do Mintex pads and considering Duralast rotors from AZ. I think this should do the trick!
I had my brake fluid changed about a year ago. Would you still recommend doing it again?
Old Mar 13, 2009 | 02:49 PM
  #28
Some Guy's Avatar
Some Guy
Generally you should change your fluid every year, but it isnt super critical, it can wait a little without causing trouble if money is tight. The main reason you change your brake fluid is because as the fluid gets water in it the boiling point lowers increasing the risk of brake fade.
Old Mar 13, 2009 | 07:18 PM
  #29
MrCooperS's Avatar
MrCooperS
Moderator
For what brake fluid is worth, I'd say do it anyways. Brake fluid is cheap and it's about 15 minutes extra to do it. Better peace of mind for less than $20 bucks.
Old Mar 16, 2009 | 07:35 AM
  #30
Bigshot's Avatar
Bigshot
Fluid changes every other year are fine, unless you do any track days.
arf88
May 31, 2016 03:07 PM
aldito2
Nov 25, 2015 09:33 PM
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
coachvminis
Aug 25, 2015 06:58 AM
