R50/53 Fog light problems.....................
Old Sep 24, 2003 | 03:10 PM
LaBoy_Mini's Avatar
LaBoy_Mini
Why is it such a pain to replacing the fog light on my MINI? There’s got to be a better way to replace the fog light other then removes the bumper from the MINI first. This is a lot of work just to be able to have my fog light bulb replace. Any commend on this anyone.
Old Sep 24, 2003 | 03:18 PM
CharlesWil's Avatar
CharlesWil
Try this link over at bridger.us/mini.com. It's is a Fog Lights install how to, I think it will help you.
Charles
Fog Lights.PDF
_________________
If you must cry over spilled milk, please try to condense it.
Old Sep 24, 2003 | 03:19 PM
LaBoy_Mini's Avatar
LaBoy_Mini
Thank you CharlesWil
Old Sep 24, 2003 | 03:29 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
You dont have to remove the bumper.
Turn the steering wheel fully towards the burned out side (this gives you clearance).
Open the hood (bonnet).
Remove the 4 plastic 'push screws' in the plastic inner fender liner that reside behind the light. You have to remove the 'screw' (you are actually withdrawing a threaded plastic pin) and then pull out the outer portion of the fastener with your fingers.
Pull back on the plastic liner.
You will see the lamp assembly inside. Release the wiring connector by lifting the locking tang then pull the connector out.
Give the bulb a quarter turn twist and then pull it out.
Reassemble in the reverse order. To reinstall the plastic fasteners, press the 'fingered' portion into the holes in the liner and body, then simply push the 'screw-pin' back into the fastener body. It needs no tightening, it's an expanding rivet-type fastener.
It's not as difficult as it sounds!
Old Sep 24, 2003 | 03:33 PM
LaBoy_Mini's Avatar
LaBoy_Mini
Really Greatbear
I will try your way first hehehehe
Thank you for your help Greatbear heheheheeh
Old Sep 24, 2003 | 03:41 PM
CharlesWil's Avatar
CharlesWil
Greatbear
I will say thanks also, that's a lot better than what I came up with.
Charles
Old Sep 24, 2003 | 10:11 PM
fuzzyface's Avatar
fuzzyface
I would think that the bulbs would be covered under warrenty. they are, on my Honda!! its just a phone call away to check. good luck
Old Sep 24, 2003 | 10:14 PM
XAlfa's Avatar
XAlfa
don't stress about it. the factory fogs are useless anyway.
Old Sep 25, 2003 | 05:14 AM
fms's Avatar
fms
A strange reply to this thread, I'd say. None of us wants to drive around w/a light out, regardless of how the fogs work!!!
Old Sep 25, 2003 | 07:54 PM
XAlfa's Avatar
XAlfa
speak for yourself. wouldn't bother me at all.
Old Sep 26, 2003 | 07:44 PM
Red's Avatar
Red
I thought all this stuff was covered under the warranty, at least for the first three years.
Regards,
Red
Sep 28, 2021 01:16 PM
Aug 21, 2015 12:58 PM
Aug 21, 2015 12:50 PM
Aug 19, 2015 12:51 PM
