R50/53 04 Cooper S outside temp blink???
Old Dec 19, 2008 | 07:21 AM
jcaimbeul's Avatar
jcaimbeul
Today there was a beep and then the outside temperature display began blinking at 32 degrees. It is 40 degrees outside. The car has been in the garage for an hour and the temperature is still blinking at 32 degrees.
Can anyone tell me what is going on?
JC
Old Dec 19, 2008 | 07:48 AM
Gil-galad's Avatar
Gil-galad
Everything you need to know:
https://www.northamericanmotoring.co...mperature.html
No worries.
Old Dec 19, 2008 | 08:25 AM
jabell2r's Avatar
jabell2r
Coordinator :: M2C2
I would guess either the sensor is bad or has come loose. On my '05 it's behind the bumper on the driver side.
Old Dec 19, 2008 | 09:10 AM
DixonL2's Avatar
DixonL2
You may have ice built up on or near the sensor... let it warm up some. The sensor is located about midway between the headlight and the centerline of the car, on the inside of the bumper skin just below the bumper beam itself. It's not visible from outside unless you remove some front end "stuff". You MAY be able to see it if you have a powerful lgiht and a dentist's mirror, poke the dentist's mirror in through the lower grille and angle up toward the headlight.
Return the mirror to the dentist when you're done.
Old Dec 19, 2008 | 10:24 AM
AggieMini11's Avatar
AggieMini11
+1
Kimolaoha
Jul 5, 2023 01:04 PM
Cereall
Sep 5, 2019 06:05 PM
Dec 23, 2015 10:36 AM
dscott90000
Aug 21, 2015 07:07 PM
