R50/53 122K, transmission acting stupid
Old Nov 23, 2008 | 12:42 PM
mokmokmini's Avatar
mokmokmini
Hey all, I got a 03 s with 122K on it and now the transmission is acting really odd. I was driving last night and it got stuck in 6th gear. When I try to shift out all the force i could put on the shifter wouldn't get it out. I let it sit for about 20 minutes and I was finally able to wrestle it out of gear but now when I try to get the shifter to move it takes hurculean strength to get it into another gear. Also, I can't seem to find third or forth. Help Please.... I was thinking it might be the gear shift lug http://www.realoem.com/bmw/showparts...85&hg=25&fg=05 right at the shift box or maybe one of the boden cables is getting stuck? Anybody ever had this sort of issue?
Old Nov 23, 2008 | 01:52 PM
Yo'sDad's Avatar
Yo'sDad
Remove the air box so you can see the cables, then disconnect the cables and try the shifter moving only the cables.
Then by hand move the tranny levers. It will be obvious very quickly as to which is stiff to move.
YD
Old Nov 23, 2008 | 02:25 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Are you on your original clutch? It might not be disengaging all the way.
Old Nov 23, 2008 | 04:36 PM
Dustin77327's Avatar
Dustin77327
you need a clutch !!!!
Old Nov 23, 2008 | 08:21 PM
mokmokmini's Avatar
mokmokmini
Thanks, I'll pull the airbox and try the cables. I'll keep you all updated.
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
beasleyboy
Sep 24, 2015 09:22 AM
slipmagt
Sep 18, 2015 06:10 AM
MiniChick82
Sep 16, 2015 02:56 PM
sirfrank
Sep 11, 2015 01:36 PM
