R50/53 Remove side scuttles R53
All threads on this I could find were only for 2nd Gen MINI's.
Does anyone know how to completely remove Side Scuttle from the panel ? Seems likely to go through bonnet, but even with flashlight is difficult to see past washer buckets to get a good look at clasp(s) ect.
From inside the fender (you might want to use a glove), push out on the peg of the scuttle, while holding the scuttle with the other hand. This is in case it falls off to avoid scratching the fender. When the scuttle comes loose, slide it out. There is nothing that really unscrews or unbolts, it's just a "friction fit". (If you can't get your hand in there you can use the flat side of a screw driver or a piece of wood or something to push the peg on the back of the scuttle out.)
...Thanks for all help
Interior/Exterior Need Help With Exterior Decisions (05' MCS PHM/W)
boostedhaze
Jan 2, 2018 07:26 PM
cm.d
Aug 19, 2015 08:51 AM
